Results 1 to 11 of 11
Thread: UT in Lieu of Radiography
    • Owners may submit Relief Request
    • Available Code cases
    – B31.1-CC 168
    – Sect III- CC N-659-2
    – Sect I & VIII- CC 2235-9
    © 2010 Electric Power Research Institute, Inc. All rights reserved. 2
    – Sect XI – CC N-713
    • Incentives
    – RT restricts personnel access
    – Use same method for fabrication and ISI examinations
    – RT can increase length of outage
    – UT can detect planar flaws reliably
    Re: UT in Lieu of Radiography
    please give me more detail about UT application in lieu of RT
    ASME B31.3 , High Pressure Piping
    K341.4.2 Radiographic and Ultrasonic Examination
    (a) All girth, longitudinal, and branch connection
    welds shall be 100% radiographically examined, except
    as permitted in (b) below.
    (b) When specified in the engineering design and with
    the owner’s approval, ultrasonic examination of welds
    may be substituted for radiographic examination where
    Tw ≥ 13 mm (1⁄2 in.).
    (c) In-process examination (see para. 344.7) shall not
    be substituted for radiographic or ultrasonic examination
    of welds.
    K341.4.3 Certifications and Records. Paragraph
    341.4.1(c) applies.
    ASME BPVC Section VIII Div-1,UW-51 a(4)
    As an alternative to the radiographic examination
    requirements above, all welds in material 1/4 in. (6 mm)
    and greater in thickness may be examined using the ultrasonic
    (UT) method per the requirements of 7.5.5 of Section
    VIII, Division 2.
    Mar 2011
    Portugal
    Please find two ASME Code cases:
    The 1/4 allowed in ASME is limited for tanks...
    API 650 Annex U - This Annex provides detailed rules for the use of the ultrasonic examination (UT) method for the examination of tank seams as permitted by 7.3.2.1. This alternative is limited to joints where the thickness of the thinner of the two members joined is greater than or equal to 10 mm (3/8 in.).
    API 620 Annex U - This annex provides detailed rules for the use of the ultrasonic examination (UT) method for the examination of tank seams as permitted by 5.26, R.7.6, and Q.7.6. This alternative is limited to joints where the thickness of the thinner of the two members joined is greater than or equal to 10 mm (3/8 in.).
    thank you for the file
  11. #9
    Deleted
  12. #10
    Deleted
  13. #11
    Deleted
  14.    Spons.
  1. Radiography for Water Pipelines
    By kronnied in forum Mechanical Engineering
    Last Post: 07-22-2013, 07:45 PM
  2. Dye penetrant test and Radiography
    By sumon emam in forum Mechanical Engineering
    Last Post: 07-13-2013, 08:22 AM
  3. Handbook of Radiography Testing
    By mnthiraviam in forum Mechanical Engineering
    Last Post: 07-07-2012, 10:25 AM
  4. Api 650 radiography inspection
    By coverall in forum Oil And Gas Production
    Last Post: 12-16-2011, 05:36 PM
  5. Industrial Radiography by R Halmshaw
    By sharmilasu in forum Mechanical Engineering
    Last Post: 10-18-2011, 03:00 PM
