Results 1 to 6 of 6
Thread: Winterizing Process Plants
    Hello,
    I am writing a General Specification about winterizing process plants.
    Unfortunately the standards or technical specifications I have seen are too general.
    So anyone interested in participating and having a copy of the standard can post his suggestion in this thread.
    I will add a copy of the standard as soon as I can learn how to do.
    Advertising world
    Re: Winterizing Process Plants
    If you're not qualified to write that why your supervisor (s) assign it to you?
    Wink Re: Winterizing Process Plants
    Quote Originally Posted by mobek View Post
    Probably I was not clear.
    I'd want to write a winterizing standard, collecting any available information, starting from zero, not using a standard from the well known engineering firms unless this is completely analyzed and possibly tested against real situations, to understand hypothesis, limits, pros and cons. (Our plants must withstand up to -50°C, is not a joke).
    So the purpose is to create a global standard that contains both theoretical and practical information; in some way it will be a Wikipedia of winterization.
    I do not have any supervisor, at the opposite I think that a general specification must be issued by the VP of the engineering division. Unfortunately during my over twenty years of experience I found that a lot of engineers use tons of specifications and data without a complete understanding of them, simply hey afford in them because "... is issued by ..." Exxon or Shell or other big firm, but what are the hypothesis, or limits or basic data? In many cases the specification was issued forty or fifty years in the past and only minor changes was taken.
    Best regards
  6. Re: Winterizing Process Plants
    This is a good initiative that is useful for young and 'old' engineers
  7. #5
    Quote Originally Posted by lmontani_IT View Post
    Best regards
    There is not so many places that you can build a plant within -50 C. I knew somes, since I worked with Russian.
    You want to write a specification for a project, so what you need to do is disscus with your project manager as well as your client. How others can answer?
    That is engineering document, but is not essay.
    @minhphuongpham: Do you come from TDH3?
  9. #6
    Best regards
  1. Process Plants: Shutdown and Turnaround Management
    By sumon emam in forum Petroleum Refining
    Last Post: 08-07-2014, 04:39 PM
  2. Kletz - Process Plants 2nd Edition
    By Azad in forum Safety And Environment
    Last Post: 04-22-2014, 06:13 PM
  3. Replies: 0
    Last Post: 02-09-2014, 12:06 PM
  4. Risk analysis for process plants
    By szarkim in forum Safety And Environment
    Last Post: 04-01-2009, 01:29 PM
