If one centrifugal pump starts without a valvle in close position, the head is near zero and the flow is infinite. Or the pump fails or the motor fails. This pump characteistic is done with nominal speed of the motor. But if you start the pump with a VFD then the pump starts can be with increase controlled flow (if the piping is filling - but take care with the reverse flow)
