Page 2 of 2 FirstFirst 1 2
Results 13 to 18 of 18
Thread: Software Etank2000 or Coade Tank 3.5
  1. #13
    May 2009
    Jubail Saudi Arabia
    Re: Software Etank2000 or Coade Tank 3.5
    Quote Originally Posted by p_alex View Post
    The calculations on ETANK are in Imperial units only (input, output and calculations). There are only an utility from Etank Programmers to conver the Output in SI units.
    For roofs, they have the self supporting dommes, umbrellas, conical, and also open tanks. Does not have external floating roofs calcs, neither ITS or Tank from Intergraph.
    For structure supported roofs, Etank as only for the conical roofs. The calculation model is based in the Brownell and Young method, please see attached file.
    But, generally, as already said in here, it is better to design the structure in a separated structural program, for example, Robot or SAP, generally because of the local regulations. Here in Europe we have Eurocodes and this tipe of structures as to be design according this Eurocodes.
    P_Alex,
    Considering the load of Roof structure mounted in the last course, Is there any provision in Etank 2000 software to consider the load imposed by structural materials to this plate course?
    Regards,
    duazo2009
    Advertising world
  3. Re: Software Etank2000 or Coade Tank 3.5
    P_Alex,
    If you are interested, download “Process Equipment Design” from Brownell & Young’s at
    Regards.
  5. Re: Software Etank2000 or Coade Tank 3.5
    It is considered only as dead load where API 650 says to consider it. See for example Table 5-21, uplift.
    To see local effect on upper course you may use FEA.
    Regards.
  6. Re: Software Etank2000 or Coade Tank 3.5
    Thank you very much for you share!
  7. Re: Software Etank2000 or Coade Tank 3.5
    pls can anybody share E tank software with keys?
  9. #18
    Thank you mate! It is really helpful!
    Newbie,, Please help
  1. Floating Roof Tank with COADE Tank
    By bowosumarwo in forum Mechanical Engineering
    Last Post: 05-25-2019, 01:37 PM
