Page 13 of 19 FirstFirst ... 3 11 12 13 14 15 ... LastLast
Results 145 to 156 of 220
Thread: Petrel Step by Step
  1. #145
    Jan 2009
    ALA, KZ
    Re: Petrel Step by Step
    To create regions in petrel you need
    2D surface with exact region geometry ( how to create it look to operation tab in surface property you will need eliminate by boundary and surface to surface operation)
    and Facies model in petrophysical modelling
    Once you there from the fall down tab choose assign values
    and use your surface to create new property in your grid
    the drawback of this is Petrel uses vertical projection to assign values of your 2D surface nodes to grid nodes and if your have tilted grid the results will not be the same as you will see it on 3D. In this case you can create script in workflow using following formulae
    FIPNUM=if (i>=$val and i<=$val1 and j>=$val2 and j<=$val3 and k>=$val4 and k<=$val5, $fip, fipnum)
    Where $val1,2,3,4,5 your boundary indexes of grid and $fip is the index of your target fip
    Advertising world
  3. Re: Petrel Step by Step
    thanks for sharing!
    Jun 2009
    Sfax, Tunisia
    he Pet People.
    just a little question; i got a petrel model and i want to update this model with production data, reservoir pressure etc.... please can any one help me (pic, steps...) to perform this job?
    gracias
  6. #148
    What you want to do after updating production and pressure data in the model?
  7. #149
    Jun 2009
    Sfax, Tunisia
    I want to review history match, to update my model. i still had three years of data to add .
    tha last update were from 2010 and i want to add untill now.
    please i need steps to perform this. thanks
  9. #150
    Prepare a well wise vol file for last 3 years. Go to Petrel. Import that vol file merging with old one.
  10. #151
    Jun 2009
    Sfax, Tunisia
    fro where can i get this well wise vol file?
  11. #152
    You have to prepare a vol file. Go to Petrel RE manual or Petrel help and you will find how you prepare and import vol file.
  12. #153
    Jun 2009
    Sfax, Tunisia
    thanks, ill try!
  13. Re: Petrel Step by Step
    I need load stratigraphic tops in Petrel, I need your help, please
  14. Re: Petrel Step by Step
    Hi all
    How can open the folder that contain the well path design step by step in petrel.
    Tnx all.
  16. #156
    Jan 2009
    ALA, KZ
  1. Replies: 11
  2. Step by step to calculate control valve Cv thorugh Intools
