hi stephenbenetjgc:
1-go to the forum where you want to start a thread or to create a post in an existing thread.
2-log in in the forum.
3-if you are going to reply to a thread, click on the "go advanced" button located at the lower right-hand corner of the quick reply box (end of the page).
4-click on the "manage attachments" button located in additional options. The "manage attachments" window will pop up. Be aware that the valid file extensions are: Bmp, doc, gif, jpe, jpeg, jpg, mp3, pdf, png, ppt, pptx, psd, rar, txt, xls, xlsx, and zip. There are also limits to the size of those files.
5-click on the "add files" button located in the right-hand side. A small box will show up.
6-click on the "select files" button. The classic "open" mswindows will appear. Go to the location your file is located, choose it and click on the "open" button.
7-click on the "upload files" button located in the small box that showed up before.
8-you should see the name of your file in the attachments section of the "manage attachments" window. If you want to attach more files, repeat steps 6 and 7. Otherwise, click on the "done" button located at the lower right-hand corner.
9-finally, click on the "submit reply" button located at the right-hand side of the window.
I tried to write down a very detailed procedure. I hope it is not confusing. A shorter version can be found in "attachments and images",
you are a new member so welcome. I see that you want to share something (giving brings you receiving). I am looking forward that you will be "an uploader/downloader" instead of just "a downloader".
