Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 13 to 24 of 110
Thread: Olga 7.0.0.
  1. #13
    Re: Olga 7.0.0.
    Help me, my OLGA 7 has work properly. but when i tried to simulate pigging in a network it doesnt work. is it because the license?
  3. Re: Olga 7.0.0.
    Hi
    i am new to this blog.
    first two links are not working and third link i could download only 60 mb. i tried many times in different systems but efforts are in vain.
    could you please upload again.
    Thanks in advance.
    Controllers in OLGA
    how use Contollers in Olga, i need set the pump speed when pressure in discharge is hight than 30 bars
    tanks
  6. #16
    Re: Olga 7.0.0.
    Link is not working.. Can anybody send the sofware to mail id megapriya06@gmail.com.. I need it very urgently
  7. #17
    Re: Olga 7.0.0.
    Hi Greges,
    I am trying to install this on Vista.
    Can you please let me know:
    - If there are any differences with following procedure for Win Vista;
    - I can't understand the way you change the .lic file; the original file is 2 pages, and I don't know where and how to implement the changes need.
    Many thanks!
    Quote Originally Posted by greges2009 View Post
    Instructions to run on XP or Wins 7 64 bit system
    - Run Setup.exe to install Olga 7
    - Select "Use a demo license (or node locked license)"
    - When SPT license handler appears, configure and select olga.lic license in -----
    - Complete install and run msxml update if needed
    - Next extract -------- directory and replace all ----- files by copying each file into the appropriate installed subdirectory.
    - copy olga.lic license in ----- into C:\Program Files (x86)\SPT Group\Licenses.
    - modify olga.lic as follows :
    SERVER your computer_name ANY 7570
    ###VENDOR scplmd
    ###USE_SERVER
    - run licmgr.exe in this folder C:\Program Files (x86)\SPT Group\FlexLm.
    - Select "Use a demo license (or node locked license)" and click "configure"
    - Browse to C:\Program Files (x86)\SPT Group\Licenses\olga.lic and the add :7570@computer_name"
    so it looks like this "7570@computer_name;C:\Program Files (x86)\SPT Group\Licenses\olga.lic". Click Ok and close.
    - run lmtools.exe in folder C:\Program Files (x86)\SPT Group\FlexLm.
    - run your software.
    To run on Windows 7 64 bits :
    + Go to Control Panel\System and Security\System\Advanced system settings. Then to Advanced tab and choose Environment Variables. In this window, you can see 2 parts, one in the upper side is User variables for [your account], the lower one is System variables.
    + Check in the System variables whether it has the Variable LM_LICENSE_FILE or not. If not, you can add a new one with detail as below:
    Variable name = LM_LICENSE_FILE
    Variable value = path to the OLGA license file (normally in Win 7 64 bit, it is located at C:\Program Files (x86)\SPT Group\Licenses\olga.lic)
    If it already has this value, you can take a look at User variables (upper side) to confirm that the variable LM_LICENSE_FILE has the value as same as the OLGA 7's license file path. If it is not same (it usually happens when you already have the previous version of OLGA installed), please correct it.
    + Run the software.
    Good luck.
  9. #18
    works very slow!
    I installed Olga 7.0.0. on "win7 x64" but it works very slow.
    Anyone can help me, Please!
  10. Re: Olga 7.0.0.
    Repost OLGA 7 Work with win7 Professional
  11. Re: Olga 7.0.0.
    the links dont let me download... i am new to this... some one help please1
  12. Re: Olga 7.0.0.
    Dear poomins and all, What a pity. I cannot download. It looks like links have been expired. Can you help to reupload. Thanks
    Quote Originally Posted by poomins View Post
  13. Re: Olga 7.0.0.
    Hi above links are working, I tested.
  14. #23
    Re: Olga 7.0.0.
    is part one 27 mb?
  16. #24
    Re: Olga 7.0.0.
    Dear egpet friend, please can anyone share with me the cr***k folder here or to me milatuibrahima@hotmail.com
    I can share a few programs if you tell me how to do it here.
    with regrads,
    kaki
