Production Data Analysis for Electric Submersible Pumped (ESP) Wells
Dr. Osman Farag Mohamed
Petroleum Engineering, PhD Ýí Petronas
Malaysia
Analyzing well performance is an important step toward increasing profits by improving production techniques. The analysis is made by field tests and examination of well data. The pump intake pressure and bottom-hole pressure are extremely important factors in analyzing Electric Submersible Pumped (ESP) well performance. Usually, the bottom-hole pressures for ESP wells are determined by an acoustic well sounding technique (recording fluid level in the annulus). But this method can not be used if the annulus is to be packed off (a packer used).
The objective of this study is to develop a method capable of calculating the pump intake pressure (PIP), the bottom hole flowing pressure (BHFP), the dynamic fluid level (DFL) & net liquid above pump (NLAP) for ESP wells using production and completion data only.
This method is based on supposing the well is natural flow (NF) from pump discharge to the surface. So, the pump discharge pressure is calculated by two phase correlations (Ha
