At early time it is definitely phase segregation. In order to model it properly you must use Hegeman model for wellbore storage, check my manual here –
[link Point to another website Only the registered members can access] By the way you not properly defined infinite radial line. At later times you response became somewhat complicated. It because of radial composite response (change in mobility and saturations) and constant pressure boundary – well drainage radius probably reached fluid contact.
If you wish I can make the match for you (absolutely free , send your saphir file to kochichiro@mail.ru, I also write a little description. But I am using Ecrin 4.10.02, so I won’t be able to open newer version (4.12.--) files.
