Results 1 to 6 of 6
Thread: Isobar map
Threaded View
  1. #3
    Jan 2009
    ALA, KZ
    In petrel if you want vertical slicing
    use following formula
    temp_pressure=if(k=4,pressure,U)
    where
    temp_pressure - new pressure property
    pressure = your initial pressure property
    k is k index of your array
    so what it will do is creating property of exact k index so you do not need to use filter
    then you can make map of the pressure for any layer you want
    And then you can write the macro which will create all maps on the fly - but this is other story my friend
  1. Article: building Pressure Map or Isobar Map
    By anprax in forum Home Articles
    Last Post: 05-13-2013, 01:18 AM
  2. building Pressure Map or Isobar Map
    By anprax in forum Geology & Exploration
    Last Post: 05-11-2013, 10:15 AM
