Results 1 to 12 of 13
Thread: WBHP not equal to WBP when a well is shut in in Eclipse
Threaded View
  1. #7
    Vino is correct
    Try this with Chap.DATA
    Very small rate " 'P1', 'ORAT' 0.010000 / "
    -- SPECIFY REPORT AT 10 DAYS
    TSTEP
    10.00000
    -- CUT OIL RATE TO 100 BPD
    WELTARG
    -- SPECIFY UPPER LIMIT OF 1 DAY FOR NEXT TIME STEP
    TUNING
    1 /
    12 1 50 /
    Then using SHUT
    TUNING
    1 /
    12 1 50 /
    TSTEP
    10.00000
    -- WELTARG
    --'P1', 'ORAT' 0.010000 /
    WELOPEN
    --'*' / opens all shut or stopped wells in the field
    'P1' SHUT / shuts well P1, if it is open
    TUNING
    1 /
    12 1 50 /
    -- ADVANCE SIMULATION TO 50 DAYS
    TSTEP
    100.00000
    WELOPEN
    --'P1' SHUT / shuts well P1, if it is open
    -- PUT OIL RATE BACK TO 1000 BPD
    WELTARG
    'P1', 'ORAT' 1000.00000 /
    TUNING
    1 /
    12 1 50 /
    In the first case you will see the pressure build up. In the second case over the same time frame it will be ZERO, just as SLB said. The well is not connected to the simulation blocks. Hence zero pressure.
    You will need this in SUMMARY to see the right results
    -- BOTTOM HOLE PRESSURE FOR WELL
    WBP
    'P1'
    WBHP
    'P1'
    —Big Oil Executive
  1. Replies: 0
    Last Post: 03-16-2013, 02:47 AM
  2. Replies: 2
    Last Post: 03-13-2013, 02:45 PM
  3. Replies: 0
    Last Post: 07-26-2011, 11:51 AM
  4. Shut-off Head Centrifugal pumps and maximum / shut-off - head
    Last Post: 07-26-2011, 09:49 AM
  5. shut-off , shut-down , start-up , pressure
    By tobbe in forum Pipeline And Fluid Flow
    Last Post: 03-12-2010, 11:44 PM
