Hello All,
Could any one please help me to get more information and/or books related to variogram and geostatistics analysis also i need to know if there is any software to make the variogram analysis
thank you very much
best regards
Hello All,
thank you very much
best regards
I have it.. trhee, but i will exchange for any software of blasting.
hello sadat666
which software you mean ??
Hello Sami22
If you want compute 2D variogran you can use variowin if 3D yo can use gslib both are free software. The very good book for undertand variogram is Introduction to applied geoestatistics by M. Srivastava. Other sofwares Wingslib, GOCAD and Petrel.
good luck
Thank you very much Viloriarj for this information, can you please tell me what is the difference between 2D and 3D variogram
Hi Sami22
Depent of your data. For exemple if you have thikness, netsand, top, botton, average of porosity, or permeability of the resevoir the variogram have to compute in 2D, the data is X,Y and the value of properties (thikness, netsand, others). Now if you have porosity, permeability in a geological unit you have compute the 3D variogram. You data have X, Y at the location well, Z each 1 meter or feet
Dear Collegues,
I'm trying to build variogram model for existing lithoface grid using gam program from GSLIB distribution. I define indicator semivariogram as variogram output type:
When I run the program I've got zeroed columns in outputCode:Parameters for GAM ****************** START OF PARAMETERS: 18_face-region.txt -file with data 1 1 - number of variables, column numbers -100 100 - trimming limits gam.out -file for variogram output 1 -grid or realization number 100 50 100.0 -nx, xmn, xsiz 200 50 100.0 -ny, ymn, ysiz 1 0.25 0.5 -nz, zmn, zsiz 2 50 -number of directions, number of lags 1 0 0 -ixd(1),iyd(1),izd(1) 0 1 0 -ixd(2),iyd(2),izd(2) 1 -standardize sill? (0=no, 1=yes) 1 -number of variograms 1 1 10 2.5 -tail variable, head variable, variogram type type 1 = traditional semivariogram 2 = traditional cross semivariogram 3 = covariance 4 = correlogram 5 = general relative semivariogram 6 = pairwise relative semivariogram 7 = semivariogram of logarithms 8 = semimadogram 9 = indicator semivariogram - continuous 10= indicator semivariogram - categorical
Can you tell me what's wrong?Code:Indicator 1/2 Variogram tail:Indicator 1 head:Indicator 1 direction 1 1 100.000 0.00000 19800 0.00000 0.00000 2 200.000 0.00000 19600 0.00000 0.00000 3 300.000 0.00000 19400 0.00000 0.00000 4 400.000 0.00000 19200 0.00000 0.00000 5 500.000 0.00000 19000 0.00000 0.00000 6 600.000 0.00000 18800 0.00000 0.00000 7 700.000 0.00000 18600 0.00000 0.00000 8 800.000 0.00000 18400 0.00000 0.00000 9 900.000 0.00000 18200 0.00000 0.00000 10 1000.000 0.00000 18000 0.00000 0.00000 11 1100.000 0.00000 17800 0.00000 0.00000 12 1200.000 0.00000 17600 0.00000 0.00000 ...
... ah, I see I give the wrong number for cutoff parameter in variogram type definition.
take this
but for me the range of variogramm is the range of your geobodies normally i take double distance between the wells
Hi temr, the link does not work. Would you like upload again. I needed to learn it. I need some books to learn about geostatistics. Thank you for help
hello...
can anybody share this book?
"Applied Geostatistics with SGeMS" by Nicholas Remy
Thanks..
