Page 1 of 2 1 2 LastLast
Results 1 to 12 of 21
Thread: ASTM Standards
  1. ASTM Standards
    Require following standards urgently.
    1. ASTM A36-14
    2. ASTM A370-17
    3. ASTM A193-16
    4. ASTM A194-16a
    5. ASTM F436-16
    6. ASTM F3125 / F3125M - 15a
    7. ASTM A325-14
    8. ASTM A123 / A123M - 15
    9. ASTM A153 / A153M - 16a
    Thanks in advance
    Re: ASTM Standards
    urgently??? why?
    Download Telegram from the Apple app store or the web* and go to the telegram GroupEgpet for the latest ASTM standards
    Let me rant for a minute...If everyone who states that they "need" really need them then they have a budget to aquire them legitimately
    Marco has posted archive files of all of the ASTMs that I have shared.
    You have been on egpet since 2011 and posted only 2 times* where is your contribution?
    OK* done with rant* I will share your request now.
    A36A36M-14 Standard Specification for Carbon Structural Steel
    A370-17 Standard Test Methods and Definitions for Mechanical Testing of Steel Products
    A193A193M-16 Standard Specification for Alloy-Steel and Stainless Steel Bolting for High Temperature or High Pressure Service and Other Special Purpose Applications
    A194A194M-16a Standard Specification for Carbon Steel* Alloy Steel* and Stainless Steel Nuts for Bolts for High Pressure or High Temperature Service* or Both
    Attached Files Attached Files
  4. Re: ASTM Standards
    Dear Sir,
    I need following standards if you please send me same;
    ASTM E1359-17
    astm e543-15
  5. Re: ASTM Standards
    Quote Originally Posted by ahmed fayyaz View Post
    Dear Sir,
    ASTM E1359-17
    astm e543-15
    E543 : 15
    Re: ASTM Standards
    I need ASTM A193-17 & ASTM A194-17a.
    anyone having the updated standards, please share.
    Re: ASTM Standards
    See the post #9
    Re: ASTM Standards
    F436F436M-16 Standard Specification for Hardened Steel Washers Inch and Metric Dimensions
    F3125F3125M-15a Standard Specification for High Strength Structural Bolts* Steel and Alloy Steel* Heat Treated* 120 ksi (830 MPa) and 150 ksi (1040 MPa) Minimum Tensile Strength* Inch and Metric Dimensions
    A325-14 Standard Specification for Structural Bolts* Steel* Heat Treated* 120-105 ksi Minimum Tensile Strength - AASHTO No. M 164
    A123A123M-15 Standard Specification for Zinc (Hot-Dip Galvanized) Coatings on Iron and Steel Products
    Re: ASTM Standards
    A153A153M-16a Standard Specification for Zinc Coating (Hot-Dip) on Iron and Steel Hardware AASHTO No. M232
  11. Re: ASTM Standards
    Sorry for not posting or contributing anything. I was recently transferred to material testing. Even i had joined this portal in 2011* i came to actively use this forum just now. Will keep posting whatever i have.
    Thank you for the standards
  12. #10
    Re: ASTM Standards
    Dear Friend
    see here
  13. Re: ASTM Standards
    Request to give ASTM A194-17a. Thanks.
  14.    Spons.
  15. Re: ASTM Standards
    Hi. Thank You everyone fro helping out. if any one could share ASTM A123 - 17 (latest)* I will really appreciate it.
  1. Replies: 13
    Last Post: 03-15-2019, 09:45 AM
  2. ASTM Standards
    By Mohamed in forum Materials Science &Corrosion
    Last Post: 06-15-2018, 12:54 AM
  3. ASTM Standards
    By mohsenkalantar in forum Materials Science &Corrosion
    Last Post: 11-15-2017, 09:53 PM
  4. ASTM D5064 , ASTM D1730, ASTM D1731, ASTM D1732 are required!
    By mohammed21 in forum Mechanical Engineering
    Last Post: 07-30-2012, 05:04 AM
  5. Need ASTM Standards
    By SA_FETY in forum Safety And Environment
    Last Post: 11-07-2009, 06:10 PM
