Thread: log log graphs
    Oct 2009
    Lahore, Pakistan.
    log log graphs
    this thread is to learn something about log-log graphs.
    I was thinking why the lines in a cycle of log are placed at different distanced from each other???
    Anyone who knows this???
    Share it........
    It is so that you can plot values of items that would not fit together on a normal scaled graph. If the distance between the lines where equal then the scales on the axes could not be shown in ascending powers of 10. ie it could only ascend by the unit scale.
    Nov 2008
    Australia
    Log-log paper is simply a graphical way of taking logs of your data to be plotted
    If we are talking base 10 logs, then;
    Log(10) = 1
    Log(100) = 2
    Log(1000) = 3
    etc
    As you can see, in log space, the 'distance' between 10 and 100 is the same as the 'distance' between 100 and 1000. Log paper just allows you to plot the 10, 100, 1000 without doing a mathematical transform first (applying a geometric transform instead I guess)
    You will get the same shape plot if you actaully takes logs first, and then plot linearly
  1. How to Use EXCEL for Graphs and Calculations
    By aan09 in forum Pipeline And Fluid Flow
    Last Post: 06-15-2011, 12:38 AM
  2. Well Production Testing Comparison with graphs and etc requirements
    By amannan in forum Oil And Gas Production
    Last Post: 12-23-2008, 09:11 AM
