Results 1 to 10 of 10
Thread: Steam turbine back pressure
  1. Steam turbine back pressure
    Hi all
    I need to know the efficiency of steam turbine (<20 kW).
    Anyone can help me?
    thk in advance!!!!
    Barbara
    Use the ASME PTC 6.
    Dec 2007
    Pakistan
    Blog Entries
    1
    plz upload asme ptc6.0. thanks.
    Please send un email to jose_manuel_freitas@yahoo.com
  8. Re: Steam turbine back pressure
    it is 95 %
    i have order one Siemens ST: 46,5 ton/h of steam, 420ºC, 46 bar , vacumm pressure= 83 mbara, Output= 11500 kW.
    you can calculate the efficiency
    i have order one Siemens ST: 46,5 ton/h of steam, 420&#186;C, 46 bar , vacumm pressure= 83 mbara, Output= 11500 kW.
  11. #9
    Efficiency is about 0.8 from isoentropic evolution but depends of the turbine.
  12. #10
    This sounds like a very small steam turbine ("<20 kW"). For such a small steam turbine, the isentropic efficiency would be in the range of 50%-55%. Allow another 2-5% for mechanical loss and 3-5% for generator loss (assuming the STG is driving a generator, and not a mechanical drive).
  1. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Planning & Project Management
    Last Post: 01-31-2011, 03:44 AM
  2. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Mechanical Engineering
    Last Post: 05-06-2010, 10:45 AM
  3. High pressure steam to reduce into low pressure steam system
    By achi81 in forum Pipeline And Fluid Flow
    Last Post: 04-27-2010, 05:02 PM
  4. Replies: 2
    Last Post: 04-19-2010, 04:57 PM
