Thread: ASME: Thickness calculation of ovale/obround tube?
    I have the following problem:
    The circular tubes are formed with rolls to have an oval or obround form .. The final form is not circular but obround. I want to calculate the thickness of these tubes according to ASME code. How?
    Re: ASME: Thickness calculation of ovale/obround tube?
    no one has the answer?
    Go Appdix 13 of ASME VIII div 1 to find the answer.
    Formally ASME code didn't have oval or obround shell thickness formula for internal pressure, but you can use Appendix 13 to approach.
  1. Permissible Variations (Tolerances) in Pipe (Tube) Wall Thickness per ASME & API
    By Abdel Halim Galala in forum Pipeline And Fluid Flow
    Last Post: 09-15-2012, 02:31 PM
  2. Pipe Thickness Calculation
    By jonas in forum Pipeline And Fluid Flow
    Last Post: 08-03-2012, 01:25 PM
  3. Tube to tube sheet joint in ASME III
    By abc123 in forum Mechanical Engineering
    Last Post: 03-12-2012, 09:55 AM
  4. Thickness gauging of Exchanger tube
    By sumon emam in forum Petroleum Refining
    Last Post: 11-15-2011, 06:41 PM
