Results 1 to 5 of 5
Thread: API 650 App P shell thickness w/repad
    I am working through the nozzle calculations per App P.2. The tank includes a repad (1/4", same as shell).
    My question is does 't' (shell thickness) include this repad ie. 1/2"?
    I can see it not being included for somthing like radial deflection or shell rotation, since the repad is only a small part of the tank shell. But if it isn't included at all, I dont see where having a repad or not benefits the calculation, ie. shouldn't the calculation with a repad produce higher allowable loads?
    Thanks.
    Daryl
  2. Re: API 650 App P shell thickness w/repad
    No Repad thickkness
  4. Re: API 650 App P shell thickness w/repad
    No Repad thickkness
    Quote Originally Posted by darylj View Post
    Thanks.
    Daryl
    no, not include.
    you can see in example problem in that annex
    the benefit of repad is you can use that annex p calculation.
    if you're not using repad for your nozzle, you can't use that calculation because the chart for determine stiffness coefficient is only for nozzle with reinforcement on shell and nozzle with reinforcement on neck only.
    hence, if you are not using repad, you haven't any reference to determine the stiffness coefficient, then you can't use that calculation.
    Thanks.
    Daryl
    no, not include.
  1. Shell thickness for an Indirect Heater
    By mattegm in forum Oil And Gas Process
    Last Post: 05-14-2019, 01:29 PM
  2. Thickness of 180 deg return
    By Riccardo in forum Mechanical Engineering
    Last Post: 12-13-2013, 06:52 PM
  3. Wall Thickness
    By Tito Saul in forum Pipeline And Fluid Flow
    Last Post: 07-30-2013, 04:06 AM
  4. Article: Shell thickness for an Indirect Heater
    By mattegm in forum Home Articles
    Last Post: 04-09-2013, 08:20 AM
