Thread: Article: SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
  1. Article: SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    You can view the page at
    Re: Article: SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    What temperature of fuel oil if your plan shutdown?
  4. Hello friend,
    Besides the already mentioned by thermal expansion mikeyles, which can contribute to sagging of the tubes is excessive deformation in tubesheets, and incorrect specification of the tube material or thickness. The ASME section VIII div. 1 part UHX provides seven conditions of loading for tubesheets, including thermal expansion.
    If you can, please send a drawing and project data over the heater for a more thorough examination.
    willianstz@gmail.com
  5. Re: Article: SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    Hello friend,
  1. ISO 16812 - Shell & Tube Heat Exchanger
    By luqman in forum Mechanical Engineering
    Last Post: 02-02-2017, 05:27 PM
  2. Replies: 0
    Last Post: 05-22-2013, 04:35 AM
  3. SHELL AND TUBE HEAT EXCHANGER (Tube Sagging Problem)
    By hammad_nrl in forum Mechanical Engineering
    Last Post: 04-10-2013, 06:06 AM
  4. Replies: 1
    Last Post: 12-11-2010, 11:36 PM
  5. tube sealing leakage in shell & tube heat exchanger
    By amitss_sam in forum Pipeline And Fluid Flow
    Last Post: 12-10-2010, 03:38 PM
