Thread: Pumping Light Oils - Delivery Flow Velocities
    As a rule of thumb the following velocities can be used in design of piping and pumping systems for light oil transport:
    Pipe Dimension Light Oils
    inches mm m/s ft/s
    1 25 1 3.5
    2 50 1.1 3.6
    3 75 1.15 3.8
    4 100 1.25 4
    6 150 1.5 4.7
    8 200 1.75 5.5
    10 250 2 6.5
    12 300 2 6.5
    Re: Pumping Light Oils - Delivery Flow Velocities
    [h=Recommended flow velocity required on the delivery side of the pump in systems with boiling liquids]2[/h]
    As a rule of thumb the following velocities can be used in design of piping and pumping systems for boiling liquids:
    Pipe Dimensions Boiling Liquids
    inches mm m/s ft/s
    1 25 1 3.5
    2 50 1.1 3.6
    3 75 1.15 3.8
    4 100 1.25 4
    6 150 1.5 4.7
    8 200 1.75 5.5
    10 250 2 6.5
    12 300 2 6.5
    The energy imparted to the water by a pump is called water horsepower and can be calculated as
    Pwhp = q h sg / 3960 (1)
    where
    Pwhp = water horsepower (hp)
    q = flow (gal/min)
    h = head (ft)
    sg = specific gravity
    The table below can be used to estimate the power requirements when pumping water.
    Volume Flow
    (gpm)
    Horsepower Required to lift water at 60oF (hp)
    Height (ft)
    5 10 15 20 25 30 35 40 50
    5 0.01 0.01 0.02 0.03 0.03 0.04 0.04 0.05 0.06
    10 0.011 0.03 0.04 0.05 0.06 0.08 0.09 0.10 0.13
    15 0.02 0.04 0.06 0.08 0.10 0.11 0.13 0.15 0.19
    20 0.03 0.05 0.08 0.10 0.13 0.15 0.18 0.20 0.25
    25 0.03 0.06 0.10 0.13 0.16 0.19 0.22 0.25 0.32
    30 0.04 0.08 0.11 0.15 0.19 0.23 0.27 0.30 0.38
    35 0.04 0.09 0.13 0.18 0.22 0.27 0.31 0.35 0.44
    40 0.05 0.10 0.15 0.20 0.25 0.30 0.35 0.40 0.51
    45 0.06 0.11 0.17 0.23 0.28 0.34 0.40 0.46 0.57
    50 0.06 0.13 0.19 0.25 0.32 0.38 0.44 0.50 0.63
    60 0.08 0.15 0.23 0.30 0.38 0.46 0.53 0.61 0.76
    70 0.09 0.18 0.27 0.35 0.44 0.53 0.62 0.71 0.88
    80 0.10 0.20 0.30 0.40 0.50 0.61 0.71 0.81 1.0
    90 0.11 0.23 0.34 0.46 0.57 0.68 0.80 0.91 1.1
    100 0.13 0.25 0.38 0.50 0.63 0.76 0.88 1.00 1.3
    Note! Individual pump curves should always be used for exact calculations.
  1. Flow rate,velocities and losses in non-circular pipes..
    By rizzyk in forum Pipeline And Fluid Flow
    Last Post: 11-11-2013, 04:11 AM
  2. Erosional velocities caculation
    By anuradha in forum Pipeline And Fluid Flow
    Last Post: 07-31-2012, 09:39 AM
  3. Replies: 0
    Last Post: 01-26-2012, 11:50 AM
  4. Recommended Velocities in Steam Systems
    By Esam in forum Pipeline And Fluid Flow
    Last Post: 07-26-2011, 04:48 PM
  5. Pumping Light Oils - Delivery Flow Velocities
    Last Post: 07-26-2011, 10:11 AM
