For a fluid flow process involving a pump or fan the overall efficiency is related to the
  • hydraulic
  • mechanical
  • volumetric
loss in the pump or fan.
[h=Hydraulic Loss and Hydraulic Efficiency]3[/h] Hydraulic loss relates to the construction of the pump or fan, and is caused by the friction between the fluid and the walls, acceleration and retardation of the fluid and the change of the fluid flow direction.
The hydraulic efficiency can be expressed as:
ηh = w / (w + wl) (1)
where
ηh = hydraulic efficiency
w = specific work from the pump or fan
wl = specific work lost due to hydraulic effects
[h=Mechanical Loss and Mechanical Efficiency]3[/h] Mechanical components - as transmission gear and bearings - generates a mechanical loss that reduces the power transferred from the motor shaft to the pump or fan impeller.
The mechanical efficiency can be expressed as:
ηm = (P - Pl) / P (2)
where
ηm = mechanical efficiency
P = power transferred from the motor to the shaft
Pl = power lost in the transmission
[h=Volumetric Loss and Volumetric Efficiency]3[/h] Due to leakage of fluid between the back surface of the impeller hub plate and the casing, or through other pump components - there is a volumetric loss reducing the pump efficiency.
The volumetric efficiency can be expressed as:
ηv = q / (q + ql) (3)
where
ηv = volumetric efficiency
q = volume flow out of the pump or fan
ql = leakage volume flow
[h=Total Loss and Overall Efficiency]3[/h] The overall efficiency is the ratio of power actually gained by the fluid to the shaft power supplied. The overall efficiency can be expressed as:
η = ηh ηm ηv (4)
where
η = overall efficiency
The losses in the pump or fan converts to heat transferred to the fluid and the surroundings. As a rule of thumb the temperature increase in a fan transporting air is approximately 1 oC.
[h=Example - Hydraulic Efficiency for a Pump]3[/h] An inline water pump works between pressure 1 bar (1 105 N/m2) and 10 bar (10 105 N/m2). Density of water is 1000 kg/m3. The hydraulic efficiency ηh = 0.91.
The actual water head (water column) can be calculated as:
h = (p2 - p1) / γ
= (p2 - p1) / ρ g
= ((10 105 N/m2) - (1 105 N/m2)) / (1,000 kg/m3) (9.81 m/s2)
= 91.7 m - water column
The pump must be constructed for the specific work:
wc = g h / ηh
= (9.81 m/s2) (91.7 m) / 0.91
= 988.6 m2/s2
The construction or design head is:
h = wc / g
= (988.6 m2/s2) / (9.81 m/s2)
= 100.8 m - water column
