Hope you can use this spreadsheet
Salam,
jonas
Salam,
jonas
Hi Jonas,
Can you Please explain me the Gas Pipe Line Sizing Calculation Please it is very urgent for me please help me with reference doc please ..........
Hi Jonas,
Hi sri,
You could see at Pipeline Rule of thumb handbook page 325.
the title is Calculate the velocity of gas in a pipeline.
Good luck!
Hi Jonas,
Please Share me Pipeline Rule of thumb handbook please .........
Hi Jonas,
Just wanted to point out a few errors in your spreadsheet. The Tabs titled ANSI B31.3, ANSI B31.4 & ANSI B31.8 should read ASME B31.3,ASME B31.4 and ASME B31.8 respectively as there are no such standards as ANSI B31.3, ANSI B31.4 and ANSI B31.8.
Thank for your correction, there is no such standard like ANSI B31.3 and etc. The correct one is what DBS123 wrote(ASME B31.3 and etc)
it's my bad, I forgot to change this tabs title. Thanks once again to DBS123.
If there are any question for this calculation that I've made, please do not hesitate to discuss about it.
Salam 'alaikum,
jonas
Hi Jonas,
Please Help me Below Gas Pipe Internal Diameter Calculation
1.Argon Gas
Flow = .90 cum/hr
Pressure = 5.10bar
Required Pipe I.D = ?
2. Oxygen
Flow = 4.90 cum/hr
Pressure = 7 bar
3.Propane
Flow = .30 cum/hr
Pressure = 7 bar
Please help me please............
If i use the spread sheet it would be 4" pipe for Argon Gas, 10" Pipe for Oxygen and 4" pipe for Propane.
Jonas,
Thank you for your reply but can u post me the calculation spread sheet for above requirement and Please Share me Pipeline Rule of thumb handbook please .........
thanks for excel file
Muhammad Khurram
interested about the handbook
