Results 1 to 5 of 5
Thread: Vertical Lift Curves (VLP/VFP) for Prosper
  1. Vertical Lift Curves (VLP/VFP) for Prosper
    Hello,
    Really much appreciate if you can help me with VFP curves.
    I need to generate VFP curves for simulation model using Prosper. Following parameters to be considered: GOR, Water-cut, AL vs BHP.
    Could you advise what exactly data I need to ask from petroleum engineers/production technologists to create this Prosper model for my well? E.g. correlations for welltest, well diameter.
    Any help appreciated.
    Easiest thing to do is go through the Prosper tutorial for an oil model demonstrated with 2 actual well test data sets.
    Markus L.
  4. Hi Markus,
    I am new in prosper and frankly speaking expecting it to be installed on my machine. Is it possible to request you to send me this 2 examples?
    I was assigned to generate VLP curves and have to make a list of data I need to request from our petroleum engineering team.
    Thanks a lot for help, appreciate it.
    Regards,
    Dev
    Dev_r,
    All you need to go through is from the start of the tutorial up to and before section 3.1.3. File size is a bit oversize. Can you post an email?
    Markus L.
  6. Hi Markus,
    Yeah sure, the email is acrotcheteer@gmail.com
    Thanks a lot.
    regards,
    Dev
  1. End scaling in Kr/Pc curves
    By arm in forum Reservoir
    Last Post: 11-27-2011, 03:39 PM
  2. Imbibition curves
    By vinomarky in forum Reservoir
    Last Post: 05-29-2011, 06:35 PM
  3. ASME B56.1-Low Lift and High Lift Trucks
    By cpchonburi in forum Mechanical Engineering
    Last Post: 04-20-2011, 08:01 AM
  4. Article: Vertical Lift Curves (VLP/VFP) for Prosper
    By dev_r in forum Home Articles
    Last Post: 04-16-2011, 11:40 PM
  5. Vertical Lift Curves (VLP/VFP) for Prosper
    By dev_r in forum Reservoir
    Last Post: 04-12-2011, 10:27 PM
