The vision for smarter plants and factories and a more efficient* connected environment is not just a concept anymore – it is a reality as we enter the era of Industry 4.0. Now more than ever* a bigger emphasis on regulatory compliance in process industries* increasing adoption of the Internet of Things (IoT) and a shift from traditional production practices to digitized methods* as well as rising demand for proactive solutions that can determine failures – even before they occur – makes connected automation a must-have in the facilities of the future. The market growth speaks for itself: According to MarketsAndMarkets research* the process automation market is expected to be valued at $62.64 billion in 2017 and is likely to reach $88.92 billion by 2023. The IoT has revolutionized the way we work* and processing plants and factories are no exception. By combining automation devices (the hardware) to information technology (IT) platforms such as manufacturing execution systems (MES)* enterprise resource planning (ERP) and business intelligence (BI) systems* greater flexibility and higher efficiency can now be provided to processing companies. Although there is a lot of hype surrounding the shift from manual processes to letting software platforms and cloud networks take the lead* the foundation of Industry 4.0 and process automation rests on the hardware. However* as the convergence of physical processing systems with the communication and control of the virtual world meld* there are certain considerations that engineers must keep in mind as they design the components and equipment used in today’s processing plants. If done right* these systems can function reliably for many years* and alert workers of bottlenecks and equipment problems to achieve drastically improved flexibility* safety and efficiency. Whether the end application is an oil and gas refinery* a chemical plant* or a wastewater treatment facility* there are several key factors to keep in mind when designing the hardware components these plants depend on.
Reliability
To work correctly* equipment must be up to code and any problems must be addressed swiftly. However* this is easier said than done when it comes to the processing industry where pipes* tanks and flues can be 50 to 100 feet above ground. Consider a typical oil and gas refinery* for instance. According to the U.S. Energy Information Administration (EIA)* of the 141 refineries in operation today* almost 90 percent were constructed before 1975. Piping systems and tanks exposed to more than 40 years of environmental factors and sometimes harsh chemicals and substances are bound to deteriorate; therefore* it is critical for each piece of equipment to work reliably and for plant operators to have the ability to remotely monitor the conditions of critical components. An explosion caused by a small leak in the piping system or an overfilled tank could be catastrophic. This is an area that is prime for automation technology and remote communication* so operators can detect problems early enough to prevent serious damage. Given the mission-critical function of the equipment and the challenging conditions under which it operates* the switches and other components built into the end products must be able to perform reliably in difficult environments for long periods of time. Engineers must keep this in mind when designing products such as pressure and flow transmitters* tank level sensors* automatic shut-off valves and control systems.
