full list 28.11.2017:
IEC 60096-0-1:2012+AMD1:2017 CSV Radio frequency cables - Part 1- 0: Guide to the design of detail specifications - Coaxial cables
IEC 60096-0-1:2012 Radio frequency cables - Part 0-1: Guide to the design of detail specifications - Coaxial cables
IEC 60096-0-1:2012/AMD1:2017 Amendment 1 - Radio frequency cables - Part 1- 0: Guide to the design of detail specifications - Coaxial cables
IEC 60339-1:1971 General purpose rigid coaxial transmission lines and their associated flange connectors. Part 1: General requirements and measuring methods
IEC 61196-1:2005 Coaxial communication cables - Part 1: Generic specification - General* definitions and requirements
IEC 61196-1-1:2007 Coaxial communication cables - Part 1-1: Capability approval for coaxial cables
IEC 61196-1-100:2015 Coaxial communication cables - Part 1-100: Electrical test methods - General requirements
IEC 61196-1-101:2005 Coaxial communication cables - Part 1-101: Electrical test methods - Test for conductor d.c. resistance of cable
IEC 61196-1-102:2005 Coaxial communication cables - Part 1-102: Electrical test methods - Test for insulation resistance of cable dielectric
IEC 61196-1-103:2015 Coaxial communication cables - Part 1-103: Electrical test methods - Test for capacitance of cable
IEC 61196-1-104:2015 Coaxial communication cables - Part 1-104: Electrical test methods - Test for the stability of the capacitance of cable versus temperature
IEC 61196-1-105:2005 Coaxial communication cables - Part 1-105: Electrical test methods - Test for withstand voltage of cable dielectric
IEC 61196-1-106:2008 Coaxial communication cables - Part 1-106: Electrical test methods - Test for withstand voltage of cable sheath
IEC 61196-1-107:2005 Coaxial communication cables - Part 1-107: Electrical test methods - Test for cable microphony charge level (mechanically induced noise)
IEC 61196-1-108:2011 Coaxial communication cables - Part 1-108: Electrical test methods - Test for characteristic impedance* phase and group delay* electrical length and propagation velocity
IEC 61196-1-110:2016 Coaxial communication cables - Part 1-110: Electrical test methods - Test for continuity
IEC 61196-1-111:2014 Coaxial communication cables - Part 1-111: Electrical test methods - Stability of phase test methods
IEC 61196-1-112:2006 Coaxial communication cables - Part 1-112: Electrical test methods - Test for return loss (uniformity of impedance)
IEC 61196-1-113:2017 PRV Coaxial communication cables - Part 1-113: Electrical test methods - Test for attenuation constant
IEC 61196-1-113:2009 Coaxial communication cables - Part 1-113: Electrical test methods - Test for attenuation constant
IEC 61196-1-114:2015 Coaxial communication cables - Part 1-114: Electrical test methods - Test for inductance
IEC 61196-1-115:2006 Coaxial communication cables - Part 1-115: Electrical test methods - Test for regularity of impedance (pulse/step function return loss)
IEC 61196-1-116:2015 Coaxial communication cables - Part 1-116: Electrical test methods - Test for impedance with time domain reflectometry (TDR)
IEC 61196-1-119:2012 Coaxial communication cables - Part 1-119: Electrical test methods - RF power rating
IEC 61196-1-122:2006 Coaxial communication cables - Part 1-122: Electrical test methods - Test for cross-talk between coaxial cables
IEC 61196-1-200:2014 Coaxial communication cables - Part 1-200: Environmental test methods - General requirements
IEC 61196-1-201:2009 Coaxial communication cables - Part 1-201: Environmental test methods - Test for cold bend performance of cable
IEC 61196-1-203:2007 Coaxial communication cables - Part 1-203: Environmental test methods - Test for water penetration of cable
IEC 61196-1-205:2008 Coaxial communication cables - Part 1-205: Environmental test methods - Resistance to solvents and contaminating fluids
IEC 61196-1-206:2017 Coaxial communication cables - Part 1-206: Environmental test methods - Climatic sequence
IEC 61196-1-208:2009 Coaxial communication cables - Part 1-208: Environmental test methods - Longitudinal pneumatic resistance
IEC 61196-1-209:2016 Coaxial communication cables - Part 1-209: Environmental test methods - Thermal cycling
IEC 61196-1-215:2016 Coaxial communication cables - Part 1-215: Environmental test methods - High temperature cable ageing
IEC 61196-1-301:2005 Coaxial communication cables - Part 1-301: Mechanical test methods - Test for ovality
IEC 61196-1-302:2005 Coaxial communication cables - Part 1-302: Mechanical test methods - Test for eccentricity
IEC 61196-1-303:2017 PRV Coaxial communication cables - Part 1-303: Mechanical test methods - Test for silver and tin plating thickness
IEC 61196-1-304:2011 Coaxial communication cables - Part 1-304: Mechanical test methods - Impact resistance
IEC 61196-1-305:2015 Coaxial communication cables - Part 1-305: Mechanical test methods - Solderability and resistance to soldering
IEC 61196-1-308:2012 Coaxial communication cables - Part 1-308: Mechanical test methods - Test for tensile strength and elongation for copper-clad metals
IEC 61196-1-310:2005 Coaxial communication cables - Part 1-310: Mechanical test methods - Test for torsion characteristics of copper-clad metals
IEC 61196-1-313:2009 Coaxial communication cables - Part 1-313: Mechanical test methods - Adhesion of dielectric and sheath
IEC 61196-1-314:2015 Coaxial communication cables - Part 1-314: Mechanical test methods - Test for bending
IEC 61196-1-316:2005 Coaxial communication cables - Part 1-316: Mechanical test methods - Test of maximum pulling force of cable
IEC 61196-1-317:2006 Coaxial communication cables - Part 1-317: Mechanical test methods - Test for crush resistance of cable
IEC 61196-1-318:2008 Coaxial communication cables - Part 1-318: Mechanical test methods - Heat performance tests
IEC 61196-1-324:2006 Coaxial communication cables - Part 1-324: Mechanical test methods - Test for abrasion resistance of cable
IEC 61196-1-325:2008 Coaxial communication cables - Part 1-325: Mechanical test methods - Aeolian vibration
IEC 61196-3:1998 Radio frequency cables - Part 3: Sectional specification for coaxial cables for use in local area networks
IEC 61196-3-1:1995 Radio-frequency cables - Part 3: Coaxial cables for digital communication in horizontal floor wiring - Section 1: Detail specification for cables of 500 m reach and up to 10 Mb/s
IEC 61196-3-2:1997 Radio frequency cables - Part 3-2: Coaxial cables for digital communication in horinzontal floor wiring - Detail specification for coaxial cables with solid dielectric for local area networks for 185 m reach and up to 10 Mb/s.
IEC 61196-3-3:1997 Radio frequency cables - Part 3-3: Coaxial cables for digital communication in horizontal floor wiring - Detail specification for coaxial cables with foamed dielectric for local area networks of 185 m reach and up to 10 Mb/s
IEC 61196-4:2015 Coaxial communication cables - Part 4: Sectional specification for radiating cables
IEC 61196-4-1:2016 Coaxial communication cables - Part 4-1: Blank detail specification for radiating cables
IEC 61196-5:2017 PRV Coaxial communication cables - Part 5: Sectional specification for CATV trunk and distribution cables
IEC 61196-5:2012 Coaxial communication cables - Part 5: Sectional specification for CATV trunk and distribution cables
IEC 61196-5-1:2012 Coaxial communication cables - Part 5-1: Blank detail specification for CATV trunk and distribution cables
IEC 61196-6:2009 Coaxial communication cables - Part 6: Sectional specification for CATV drop cables
IEC 61196-6-1:2009 Coaxial communication cables - Part 6-1: Blank detail specification for CATV drop cables
IEC 61196-6-2:2017 PRV Coaxial communication cables - Part 6-2: Detail specification for 75-4 type CATV drop cables
IEC 61196-6-3:2017 PRV Coaxial communication cables - Part 6-3: Detail specification for type 75-5 CATV drop cables
IEC 61196-6-4:2017 PRV Coaxial communication cables - Part 6-4: Detail specification for 75-7 type CATV drop cables
IEC 61196-7:2011 Coaxial communication cables - Part 7: Sectional specification for cables for BCT cabling in accordance with ISO/IEC 15018 - Indoor drop cables for systems operating at 5 MHz - 3 000 MHz
IEC 61196-8:2012 Coaxial communication cables - Part 8: Sectional specification for semi-flexible cables with polytetrafluoroethylene (PTFE) dielectric
IEC 61196-8-1:2012 Coaxial communication cables - Part 8-1: Blank detail specification for semi-flexible cables with polytetrafluoroethylene (PTFE) dielectric
IEC 61196-8-1:2012 Coaxial communication cables - Part 8-2: Detail specification for 50-047 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-8-3:2012 Coaxial communication cables - Part 8-3: Detail specification for 50-086 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-8-4:2012 Coaxial communication cables - Part 8-4: Detail specification for 50-141 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-8-5:2012 Coaxial communication cables - Part 8-5: Detail specification for 50-250 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-8-6:2012 Coaxial communication cables - Part 8-6: Detail specification for 75-047 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-8-7:2012 Coaxial communication cables - Part 8-7: Detail specification for 75-086 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-8-8:2012 Coaxial communication cables - Part 8-8: Detail specification for 75-141 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-8-9:2012 Coaxial communication cables - Part 8-9: Detail specification for 75-250 type semi-flexible cables with solid polytetrafluoroethylene (PTFE) insulation
IEC 61196-9:2014 Coaxial communication cables - Part 9: Sectional specification for RF flexible cables
IEC 61196-9-1:2015 Coaxial communication cables - Part 9-1: Flexible RF coaxial cables - Blank detail specification
IEC 61196-10:2014 Coaxial communication cables - Part 10: Sectional specification for semi-rigid cables with polytetrafluoroethylene (PTFE) dielectric
IEC 61196-10:2014/COR1:2016 Corrigendum 1 - Coaxial communication cables - Part 10: Sectional specification for semi-rigid cables with polytetrafluoroethylene (PTFE) dielectric
IEC 61196-10-1:2014 Coaxial communication cables - Part 10-1: Blank detail specification for semi-rigid cables with polytetrafluoroethylene (PTFE) dielectric
IEC 61196-11:2016 Coaxial communication cables - Part 11: Sectional specification for semi-rigid cables with polyethylene (PE) dielectric
IEC 61196-11-1:2016 Coaxial communication cables - Part 11-1: Blank detail specification for semi-rigid cables with polyethylene (PE) dielectric
IEC 62153-1-1:2003 Metallic communication cables test methods - Part 1-1: Electrical - Measurement of the pulse/step return loss in the frequency domain using the Inverse Discrete Fourier Transformation (IDFT)
the missing:
