full list 26.11.2017:
IEC TR 62063:1999 High-voltage switchgear and controlgear - The use of electronic and associated technologies in auxiliary equipment of switchgear and controlgear
IEC 62271:2017 SER High-voltage switchgear and controlgear - ALL PARTS
IEC 62271-4:2013 High-voltage switchgear and controlgear - Part 4: Handling procedures for sulphur hexafluoride (SF6) and its mixtures
IEC/IEEE 62271-37-013:2015 High-voltage switchgear and controlgear - Part 37-013: Alternating-current generator circuit-breakers
IEC/IEEE 62271-37-013:2015/COR1:2017 Corrigendum 1 - High-voltage switchgear and controlgear - Part 37-013: Alternating-current generator circuit-breakers
IEC/IEEE 62271-37-082:2012 High-voltage switchgear and controlgear - Part 37-082: Standard practice for the measurement of sound pressure levels on alternating current circuit-breakers
IEC/IEEE 62271-37-082:2012/COR1:2014 Corrigendum 1 - High-voltage switchgear and controlgear - Part 37-082: Standard practice for the measurement of sound pressure levels on alternating current circuit-breakers
IEC 62271-100:2008+AMD1:2012+AMD2:2017 CSV High-voltage switchgear and controlgear - Part 100: Alternating-current circuit-breakers
IEC 62271-100:2008+AMD1:2012 CSV High-voltage switchgear and controlgear - Part 100: Alternatingcurrent circuit-breakers
IEC 62271-100:2008 High-voltage switchgear and controlgear - Part 100: Alternating current circuit-breakers
IEC 62271-100:2008/AMD1:2012 Amendment 1 - High-voltage switchgear and controlgear - Part 100: Alternating current circuit-breakers
IEC 62271-100:2008/AMD1:2012/COR1:2012 Corrigendum 1 - Amendment 1 - High-voltage switchgear and controlgear - Part 100: Alternating-current circuit-breakers
IEC 62271-100:2008/AMD2:2017 Amendment 2 - High-voltage switchgear and controlgear - Part 100: Alternating-current circuit-breakers
IEC 62271-101:2012 High-voltage switchgear and controlgear - Part 101: Synthetic testing
IEC 62271-102:2001+AMD1:2011+AMD2:2013 CSV High-voltage switchgear and controlgear - Part 102: Alternatingcurrent disconnectors and earthing switches
IEC 62271-102:2001+AMD1:2011 CSV High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-102:2001 High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-102:2001/COR1:2002 Corrigendum 1 - High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-102:2001/COR2:2003 Corrigendum 2 - High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-102:2001/COR3:2005 Corrigendum 3 - High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-102:2001/COR4:2014 Corrigendum 4 - High-voltage switchgear and controlgear - Part 102: Alternanting current disconnectors and earthing switches
IEC 62271-102:2001/AMD1:2011 Amendment 1 - High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-102:2001/AMD1:2011/COR1:2012 Corrigendum 1 - Amendment 1 - High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-102:2001/AMD2:2013 Amendment 2 - High-voltage switchgear and controlgear - Part 102: Alternating current disconnectors and earthing switches
IEC 62271-103:2011 High-voltage switchgear and controlgear - Part 103: Switches for rated voltages above 1 kV up to and including 52 kV
IEC 62271-103:2011/COR1:2013 Corrigendum 1 - High-voltage switchgear and controlgear - Part 103: Switches for rated voltages above 1 kV up to and including 52 kV
IEC 62271-104:2015 High-voltage switchgear and controlgear - Part 104: Alternating current switches for rated voltages higher than 52 kV
IEC 62271-105:2012 High-voltage switchgear and controlgear - Part 105: Alternating current switch-fuse combinations for rated voltages above 1 kV up to and including 52 kV
IEC 62271-106:2011 High-voltage switchgear and controlgear - Part 106: Alternating current contactors* contactor-based controllers and motor-starters
IEC 62271-106:2011/COR1:2014 Corrigendum 1 - High-voltage switchgear and controlgear - Part 106: Alternating current contactors* contactor-based controllers and motor-starters
IEC 62271-107:2012 High-voltage switchgear and controlgear - Part 107: Alternating current fused circuit-switchers for rated voltages above 1 kV up to and including 52 kV
IEC 62271-108:2005 High-voltage switchgear and controlgear - Part 108: High-voltage alternating current disconnecting circuit-breakers for rated voltages of 72*5 kV and above
IEC 62271-109:2008+AMD1:2013 CSV High-voltage switchgear and controlgear - Part 109: Alternating-current series capacitor by-pass switches
IEC 62271-109:2008 High-voltage switchgear and controlgear - Part 109: Alternating-current series capacitor by-pass switches
IEC 62271-109:2008/AMD1:2013 Amendment 1 - High-voltage switchgear and controlgear - Part 109: Alternating-current series capacitor by-pass switches
IEC 62271-110:2017 RLV High-voltage switchgear and controlgear - Part 110: Inductive load switching
IEC 62271-110:2017 High-voltage switchgear and controlgear - Part 110: Inductive load switching
IEC 62271-111:2012 High-voltage switchgear and controlgear - Part 111: Automatic circuit reclosers and fault interrupters for alternating current systems up to 38 kV
IEC 62271-112:2013 High-voltage switchgear and controlgear - Part 112: Alternating current high-speed earthing switches for secondary arc extinction on transmission lines
IEC TR 62271-300:2006 High-voltage switchgear and controlgear - Part 300: Seismic qualification of alternating current circuit-breakers
IEC TR 62271-301:2009 High-voltage switchgear and controlgear - Part 301: Dimensional standardisation of high-voltage terminals
IEC TR 62271-302:2010 High-voltage switchgear and controlgear - Part 302: Alternating current circuit-breakers with intentionally non-simultaneous pole operation
IEC TR 62271-305:2009 High-voltage switchgear and controlgear - Part 305: Capacitive current switching capability of air-insulated disconnectors for rated voltages above 52 kV
IEC TR 62271-305:2009/COR1:2017 Corrigendum 1 - High-voltage switchgear and controlgear - Part 305: Capacitive current switching capability of air-insulated - Disconnectors for rated voltages above 52 kV
IEC TR 62271-306:2012 High-voltage switchgear and controlgear - Part 306: Guide to IEC 62271-100* IEC 62271-1 and other IEC standards related to alternating current circuit-breakers
IEC TR 62271-310:2008 High-voltage switchgear and controlgear - Part 310: Electrical endurance testing for circuit-breakers above a rated voltage of 52 kV
the missing:
