ISO TC 106 standards
ISO 7405:2008 Dentistry -- Evaluation of biocompatibility of medical devices used in dentistry
ISO 7405:2008/AMD 1:2013 Positive control material
Filling and restorative materials
ISO 3107:2011 Dentistry -- Zinc oxide/eugenol cements and zinc oxide/non-eugenol cements
ISO 4049:2009 Dentistry -- Polymer-based restorative materials
ISO 6874:2015 Dentistry -- Polymer-based pit and fissure sealants
ISO 6876:2012 Dentistry -- Root canal sealing materials
ISO 6877:2006 Dentistry -- Root-canal obturating points
ISO 7551:1996 Dental absorbent points
ISO 9917-1:2007 Dentistry -- Water-based cements -- Part 1: Powder/liquid acid-base cements
ISO 9917-2:2017 Dentistry -- Water-based cements -- Part 2: Resin-modified cements
ISO/TS 11405:2015 Dentistry -- Testing of adhesion to tooth structure
ISO 13116:2014 Dentistry -- Test method for determining radio-opacity of materials
ISO 15841:2014 Dentistry -- Wires for use in orthodontics
ISO/TS 16506:2017 Dentistry -- Polymer-based luting materials containing adhesive components
ISO 17254:2016 Dentistry -- Coiled springs for use in orthodontics
ISO 17304:2013 Dentistry -- Polymerization shrinkage: Method for determination of polymerization shrinkage of polymer-based restorative materials
ISO/TS 17988:2014 Dentistry -- Corrosion test methods for dental amalgam
ISO/TS 20746:2016 Dentistry -- Determination of the strength of dental amalgam by the Hertzian indentation strength (HIT) method
ISO 20749:2017 Dentistry -- Pre-capsulated dental amalgam
ISO 21606:2007 Dentistry -- Elastomeric auxiliaries for use in orthodontics
ISO 24234:2015 Dentistry -- Dental amalgam
ISO 27020:2010 Dentistry -- Brackets and tubes for use in orthodontics
ISO 29022:2013 Dentistry -- Adhesion -- Notched-edge shear bond strength test
Prosthodontic materials
ISO 4823:2015 Dentistry -- Elastomeric impression materials
ISO 6872:2015 Dentistry -- Ceramic materials
ISO 6873:2013 Dentistry -- Gypsum products
ISO 7491:2000 Dental materials -- Determination of colour stability
ISO 9333:2006 Dentistry -- Brazing materials
ISO 9693-1:2012 Dentistry -- Compatibility testing -- Part 1: Metal-ceramic systems
ISO 9693-2:2016 Dentistry -- Compatibility testing -- Part 2: Ceramic-ceramic systems
ISO 10139-1:2005 Dentistry -- Soft lining materials for removable dentures -- Part 1: Materials for short-term use
ISO 10139-1:2005/Cor 1:2006 Dentistry -- Soft lining materials for removable dentures -- Part 1: Materials for short-term use
ISO 10139-2:2016 Dentistry -- Soft lining materials for removable dentures -- Part 2: Materials for long-term use
ISO 10271:2011 Dentistry -- Corrosion test methods for metallic materials
ISO 10477:2004 Dentistry -- Polymer-based crown and bridge materials
ISO 13017:2012 Dentistry -- Magnetic attachments
ISO 13017:2012/Amd 1:2015 Dentistry -- Magnetic attachments
ISO 13078:2013 Dentistry -- Dental furnace -- Test method for temperature measurement with separate thermocouple
ISO 13078-2:2016 Dentistry -- Dental furnace -- Part 2: Test method for evaluation of furnace programme via firing glaze
ISO 14233:2003 Dentistry -- Polymer-based die materials
ISO 14356:2003 Dentistry -- Duplicating material
ISO/TR 14569-1:2007 Dental materials -- Guidance on testing of wear -- Part 1: Wear by toothbrushing
ISO/TS 14569-2:2001 Dental materials -- Guidance on testing of wear -- Part 2: Wear by two- and/or three body contact
ISO 15854:2005 Dentistry -- Casting and baseplate waxes
ISO 15912:2016 Dentistry -- Refractory investment and die material
ISO/TS 19736:2017 Dentistry -- Bonding test between polymer teeth and denture base materials
ISO 20795-1:2013 Dentistry -- Base polymers -- Part 1: Denture base polymers
ISO 20795-2:2013 Dentistry -- Base polymers -- Part 2: Orthodontic base polymers
ISO 21563:2013 Dentistry -- Hydrocolloid impression materials
ISO 22112:2017 Dentistry -- Artificial teeth for dental prostheses
ISO 22674:2016 Dentistry -- Metallic materials for fixed and removable restorations and appliances
ISO 28319:2010 Dentistry -- Laser welding
ISO/TR 28642:2016 Dentistry -- Guidance on colour measurement
Terminology
ISO 1942:2009 Dentistry -- Vocabulary
ISO 3950:2016 Dentistry -- Designation system for teeth and areas of the oral cavity
ISO/TR 15300:2001 Dentistry -- Application of OSI clinical codification to the classification and coding of dental products
ISO/TR 15599:2002 Digital codification of dental laboratory procedures
ISO/TR 15599:2002/Cor 1:2003 Digital codification of dental laboratory procedures
ISO 16059:2007 Dentistry -- Required elements for codification used in data exchange
ISO 16443:2014 Dentistry -- Vocabulary for dental implants systems and related procedure
Dental instruments
ISO 1797:2017 Dentistry -- Shanks for rotary and oscillating instruments
ISO 2157:2016 Dentistry -- Nominal diameters and designation code numbers for rotary instruments
ISO 3630-1:2008 Dentistry -- Root-canal instruments -- Part 1: General requirements and test methods
ISO 3630-2:2013 Dentistry -- Endodontic instruments -- Part 2: Enlargers
ISO 3630-3:2015 Dentistry -- Endodontic instruments -- Part 3: Compactors: pluggers and spreaders
ISO 3630-4:2009 Dentistry -- Root canal instruments -- Part 4: Auxiliary instruments
ISO 3630-5:2011 Dentistry -- Endodontic instruments -- Part 5: Shaping and cleaning instruments
ISO 3823-1:1997 Dental rotary instruments -- Burs -- Part 1: Steel and carbide burs
ISO 3823-2:2003 Dentistry -- Rotary bur instruments -- Part 2: Finishing burs
ISO 3823-2:2003/Amd 1:2008 Dentistry -- Rotary bur instruments -- Part 2: Finishing burs
ISO 3964:2016 Dentistry -- Coupling dimensions for handpiece connectors
ISO 6360-1:2004 Dentistry -- Number coding system for rotary instruments -- Part 1: General characteristics
ISO 6360-1:2004/Cor 1:2007 Dentistry -- Number coding system for rotary instruments -- Part 1: General characteristics
ISO 6360-2:2004 Dentistry -- Number coding system for rotary instruments -- Part 2: Shapes
ISO 6360-2:2004/Amd 1:2011 Dentistry -- Number coding system for rotary instruments -- Part 2: Shapes
ISO 6360-3:2005 Dentistry -- Number coding system for rotary instruments -- Part 3: Specific characteristics of burs and cutters
ISO 6360-4:2004 Dentistry -- Number coding system for rotary instruments -- Part 4: Specific characteristics of diamond instruments
ISO 6360-5:2007 Dentistry -- Number coding system for rotary instruments -- Part 5: Specific characteristics of root-canal instruments
ISO 6360-6:2004 Dentistry -- Number coding system for rotary instruments -- Part 6: Specific characteristics of abrasive instruments
ISO 6360-7:2006 Dentistry -- Number coding system for rotary instruments -- Part 7: Specific characteristics of mandrels and special instruments
ISO 7492:1997 Dental explorers
ISO 7711-1:1997 Dental rotary instruments -- Diamond instruments -- Part 1: Dimensions* requirements* marking and packaging
ISO 7711-1:1997/Amd 1:2009 Dental rotary instruments -- Diamond instruments -- Part 1: Dimensions* requirements* marking and packaging
ISO 7711-2:2011 Dentistry -- Rotary diamond instruments -- Part 2: Discs
ISO 7711-3:2004 Dentistry -- Diamond rotary instruments -- Part 3: Grit sizes* designation and colour code
ISO 7786:2001 Dental rotary instruments -- Laboratory abrasive instruments
ISO 7787-1:2016 Dentistry -- Laboratory cutters -- Part 1: Steel laboratory cutters
ISO 7787-2:2000 Dental rotary instruments -- Cutters -- Part 2: Carbide laboratory cutters
ISO 7787-3:2017 Dentistry -- Laboratory cutters -- Part 3: Carbide cutters for milling machines
ISO 7787-4:2002 Dental rotary instruments -- Cutters -- Part 4: Miniature carbide laboratory cutters
ISO 7885:2010 Dentistry -- Sterile injection needles for single use
ISO 8325:2004 Dentistry -- Test methods for rotary instruments
ISO 9168:2009 Dentistry -- Hose connectors for air driven dental handpieces
ISO 9173-1:2016 Dentistry -- Extraction forceps -- Part 1: General requirements
ISO 9173-2:2010 Dentistry -- Extraction forceps -- Part 2: Designation
ISO 9173-3:2014 Dentistry -- Extraction forceps -- Part 3: Design
ISO 9873:2017 Dentistry -- Intra-oral mirrors
ISO 9997:1999 Dental cartridge syringes
ISO 10323:2013 Dentistry -- Bore diameters for rotary instruments such as discs and wheels
ISO 11499:2014 Dentistry -- Single-use cartridges for local anaesthetics
ISO 13295:2007 Dentistry -- Mandrels for rotary instruments
ISO 13397-1:1995 Periodontal curettes* dental scalers and excavators -- Part 1: General requirements
ISO 13397-2:2005 Dentistry -- Periodontal curettes* dental scalers and excavators -- Part 2: Periodontal curettes of Gr-type
ISO 13397-2:2005/Amd 1:2012 Colour coding
ISO 13397-3:1996 Periodontal curettes* dental scalers and excavators -- Part 3: Dental scalers -- H-type
ISO 13397-4:1997 Periodontal curettes* dental scalers and excavators -- Part 4: Dental excavators -- Discoid-type
ISO 13397-5:2015 Dentistry -- Periodontal curettes* dental scalers and excavators -- Part 5: Jacquette scalers
ISO 13504:2012 Dentistry -- General requirements for instruments and related accessories used in dental implant placement and treatment
ISO 14457:2012 Dentistry -- Handpieces and motors
ISO 15087-1:1999 Dental elevators -- Part 1: General requirements
ISO 15087-2:2000 Dental elevators -- Part 2: Warwick James elevators
ISO 15087-3:2000 Dental elevators -- Part 3: Cryer elevators
ISO 15087-4:2000 Dental elevators -- Part 4: Coupland elevators
ISO 15087-5:2000 Dental elevators -- Part 5: Bein elevators
ISO 15087-6:2000 Dental elevators -- Part 6: Flohr elevators
ISO 15098-1:1999 Dental tweezers -- Part 1: General requirements
ISO 15098-2:2000 Dental tweezers -- Part 2: Meriam types
ISO 15098-3:2000 Dental tweezers -- Part 3: College types
ISO 16635-1:2013 Dentistry -- Dental rubber dam technique -- Part 1: Hole punch
ISO 16635-2:2014 Dentistry -- Dental rubber dam instruments -- Part 2: Clamp forceps
ISO 17509:2016 Dentistry -- Torque transmitter for handpieces
ISO 17937:2015 Dentistry -- Osteotome
ISO 18397:2016 Dentistry -- Powered scaler
ISO 18556:2016 Dentistry -- Intraoral spatulas
ISO 19490:2017 Dentistry -- Sinus membrane elevator
ISO 19715:2017 Dentistry -- Filling instrument with contra angle
ISO 21531:2009 Dentistry -- Graphical symbols for dental instruments
ISO 21533:2003 Dentistry -- Reusable cartridge syringes intended for intraligamentary injections
ISO 21533:2003/Cor 1:2009 Dentistry -- Reusable cartridge syringes intended for intraligamentary injections
ISO 21671:2006 Dentistry -- Rotary polishers
ISO 21671:2006/Amd 1:2011 Dentistry -- Rotary polishers
ISO 21672-1:2012 Dentistry -- Periodontal probes -- Part 1: General requirements
ISO 21672-2:2012 Dentistry -- Periodontal probes -- Part 2: Designation
Dental equipment
ISO 4073:2009 Dentistry -- Information system on the location of dental equipment in the working area of the oral health care provider
ISO 6875:2011 Dentistry -- Patient chair
ISO 7488:1991 Dental amalgamators
ISO 7493:2006 Dentistry -- Operator's stool
ISO 7494-1:2011 Dentistry -- Dental units -- Part 1: General requirements and test methods
ISO 7494-2:2015 Dentistry -- Dental units -- Part 2: Air* water* suction and wastewater systems
ISO 8282:1994 Dental equipment -- Mercury and alloy mixers and dispensers
ISO 9680:2014 Dentistry -- Operating lights
ISO 9687:2015 Dentistry -- Graphical symbols for dental equipment
ISO 10637:1999 Dental equipment -- High- and medium-volume suction systems
ISO 10650:2015 Dentistry -- Powered polymerization activators
ISO 11143:2008 Dentistry -- Amalgam separators
ISO 13897:2003 Dentistry -- Amalgam capsules
ISO 13897:2003/Cor 1:2003 Dentistry -- Amalgam capsules
ISO 16954:2015 Dentistry -- Test methods for dental unit waterline biofilm treatment
ISO 21530:2004 Dentistry -- Materials used for dental equipment surfaces -- Determination of resistance to chemical disinfectants
ISO/TS 22595-1:2006 Dentistry -- Plant area equipment -- Part 1: Suction systems
ISO/TS 22595-2:2008 Dentistry -- Plant area equipment -- Part 2: Compressor systems
IEC 80601-2-60:2012 Medical electrical equipment -- Part 2-60: Particular requirements for basic safety and essential performance of dental equipment
Oral care products
ISO 10873:2010 Dentistry -- Denture adhesives
ISO 11609:2017 Dentistry -- Dentifrices -- Requirements* test methods and marking
ISO 16408:2015 Dentistry -- Oral care products -- Oral rinses
ISO 16409:2016 Dentistry -- Oral care products -- Manual interdental brushes
ISO 17730:2014 Dentistry -- Fluoride varnishes
ISO 20126:2012 Dentistry -- Manual toothbrushes -- General requirements and test methods
ISO 20127:2005 Dentistry -- Powered toothbrushes -- General requirements and test methods
ISO 22254:2005 Dentistry -- Manual toothbrushes -- Resistance of tufted portion to deflection
ISO 28158:2010 Dentistry -- Integrated dental floss and handles
ISO 28399:2011 Dentistry -- Products for external tooth bleaching
ISO 28888:2013 Dentistry -- Screening method for erosion potential of oral rinses on dental hard tissues
Dental implants
ISO 10451:2010 Dentistry -- Contents of technical file for dental implant systems
ISO 11953:2010 Dentistry -- Implants -- Clinical performance of hand torque instruments
ISO/TS 13498:2011 Dentistry -- Torsion test of implant body/connecting part joints of endosseous dental implant systems
ISO 14801:2016 Dentistry -- Implants -- Dynamic loading test for endosseous dental implants
ISO 16498:2013 Dentistry -- Minimal dental implant data set for clinical use
ISO/TR 18130:2016 Dentistry -- Screw loosening test using cyclic torsional loading for implant body/implant abutment connection of endosseous dental implants
ISO 19429:2015 Dentistry -- Designation system for dental implants
ISO 22794:2007 Dentistry -- Implantable materials for bone filling and augmentation in oral and maxillofacial surgery -- Contents of a technical file
ISO 22803:2004 Dentistry -- Membrane materials for guided tissue regeneration in oral and maxillofacial surgery -- Contents of a technical file
ISO/TS 22911:2016 Dentistry -- Preclinical evaluation of dental implant systems -- Animal test methods
Dental CAD/CAM systems
ISO 12836:2015 Dentistry -- Digitizing devices for CAD/CAM systems for indirect dental restorations -- Test methods for assessing accuracy
ISO 18739:2016 Dentistry -- Vocabulary of process chain for CAD/CAM systems
ISO/TR 18845:2017 Dentistry -- Test methods for machining accuracy of computer-aided milling machines
missing:
