ISO/TC 39 STANDARDS
ISO 229:1973 Machine tools -- Speeds and feeds
ISO 298:1973 Machine tools -- Lathe centres -- Sizes for interchangeability
ISO 299:1987 Machine tool tables -- T-slots and corresponding bolts
ISO 369:2009 Machine tools -- Symbols for indications appearing on machine tools
ISO 447:1984 Machine tools -- Direction of operation of controls
ISO 2562:1973 Modular units for machine tool construction -- Slide units
ISO 2562:1973/Amd 1:1982 Modular units for machine tool construction -- Slide units
ISO 2727:1973 Modular units for machine tool construction -- Headstocks
ISO 2769:1973 Modular units for machine tool construction -- Wing bases for slide units
ISO 2891:1977 Modular units for machine tool construction -- Centre bases and columns
ISO 2905:1985 Modular units for machine tool construction -- Spindle noses and adjustable adaptors for multi-spindle heads
ISO 2912:1973 Modular units for machine tool construction -- Multi-spindle heads -- Casing and input drive shaft dimensions
ISO 2912:1973/Amd 1:1982 Modular units for machine tool construction -- Multi-spindle heads -- Casing and input drive shaft dimensions
ISO 2934:1973 Modular units for machine tool construction -- Wing base for columns
ISO 3371:1975 Modular units for machine tool construction -- Rotary tables and multi-sided centre bases for rotary tables
ISO 3408-1:2006 Ball screws -- Part 1: Vocabulary and designation
ISO 3408-2:1991 Ball screws -- Part 2: Nominal diameters and nominal leads -- Metric series
ISO 3408-3:2006 Ball screws -- Part 3: Acceptance conditions and acceptance tests
ISO 3408-4:2006 Ball screws -- Part 4: Static axial rigidity
ISO 3408-5:2006 Ball screws -- Part 5: Static and dynamic axial load ratings and operational life
ISO 3476:1975 Modular units for machine tool construction -- Tenon drive and flanges for mounting multi- spindle heads
ISO 3589:1975 Modular units for machine tool construction -- Integral way columns
ISO 3589:1975/Amd 1:1982 Modular units for machine tool construction -- Integral way columns
ISO 3590:1976 Modular units for machine tool construction -- Spindle units
ISO 3610:1976 Modular units for machine tool construction -- Support brackets
ISO 3970:1977 Modular units for machine tool construction -- Integral way columns -- Floor-mounted type
ISO 3970:1977/Amd 1:1982 Modular units for machine tool construction -- Integral way columns -- Floor-mounted type
ISO 5169:1977 Machine tools -- Presentation of lubrication instructions
ISO 5170:1977 Machine tools -- Lubrication systems
ISO 6898:1984 Open front mechanical power presses -- Capacity ratings and dimensions
ISO 6899:1984 Acceptance conditions of open front mechanical power presses -- Testing of the accuracy
ISO 8526-1:1990 Modular units for machine tools -- Workholding pallets -- Part 1: Workholding pallets up to 800 mm nominal size
ISO 8526-2:1990 Modular units for machine tools -- Workholding pallets -- Part 2: Workholding pallets of nominal size greater than 800 mm
ISO 8526-2:1990/Cor 1:1992 Modular units for machine tools -- Workholding pallets -- Part 2: Workholding pallets of nominal size greater than 800 mm
ISO 8540:1993 Open front mechanical power presses -- Vocabulary
ISO 9188:1993 Machine tools -- Straight-sided single-action mechanical power presses from 400 kN up to and including 4 000 kN nominal force -- Characteristics and dimensions
ISO 9189:1993 Machine tools -- Straight-sided high-speed mechanical power presses from 250 kN up to and including 4 000 kN nominal force -- Characteristics and dimensions
ISO 14955-1:2014 Machine tools -- Environmental evaluation of machine tools -- Part 1: Design methodology for energy-efficient machine tools
ISO 23848-1:2009 Machine tools -- Ball splines -- Part 1: General characteristics and requirements
ISO 23848-2:2009 Machine tools -- Ball splines -- Part 2: Dynamic and static load ratings and rating life
ISO 29262:2011 Production equipment for microsystems -- Interface between end effector and handling system
Test conditions for metal cutting machine tools
ISO 230-1:2012 Test code for machine tools -- Part 1: Geometric accuracy of machines operating under no-load or quasi-static conditions
ISO 230-2:2014 Test code for machine tools -- Part 2: Determination of accuracy and repeatability of positioning of numerically controlled axes
ISO 230-2:2014/Amd 1:2016 Test code for machine tools -- Part 2: Determination of accuracy and repeatability of positioning of numerically controlled axes
ISO 230-3:2007 Test code for machine tools -- Part 3: Determination of thermal effects
ISO 230-4:2005 Test code for machine tools -- Part 4: Circular tests for numerically controlled machine tools
ISO 230-6:2002 Test code for machine tools -- Part 6: Determination of positioning accuracy on body and face diagonals (Diagonal displacement tests)
ISO 230-7:2015 Test code for machine tools -- Part 7: Geometric accuracy of axes of rotation
ISO/TR 230-8:2010 Test code for machine tools -- Part 8: Vibrations
ISO/TR 230-9:2005 Test code for machine tools -- Part 9: Estimation of measurement uncertainty for machine tool tests according to series ISO 230* basic equations
ISO 230-10:2016 Test code for machine tools -- Part 10: Determination of the measuring performance of probing systems of numerically controlled machine tools
ISO 1701-1:2004 Test conditions for milling machines with table of variable height -- Testing of the accuracy -- Part 1: Machines with horizontal spindle
ISO 1701-2:2004 Test conditions for milling machines with table of variable height -- Testing of accuracy -- Part 2: Machines with vertical spindle
ISO 1708:1989 Acceptance conditions for general purpose parallel lathes -- Testing of the accuracy
ISO 1984-1:2001 Test conditions for manually controlled milling machines with table of fixed height - Testing of the accuracy -- Part 1: Machines with horizontal spindle
ISO 1984-2:2001 Test conditions for manually controlled milling machines with table of fixed height - Testing of the accuracy -- Part 2: Machines with vertical spindle
ISO 1985:2015 Machine tools -- Test conditions for surface grinding machines with vertical grinding wheel spindle and reciprocating table -- Testing of the accuracy
ISO 1986-1:2014 Test conditions for surface grinding machines with horizontal grinding wheel spindle and reciprocating table -- Testing of the accuracy -- Part 1: Machines with table length of up to 1 600 mm
ISO 2407:1997 Test conditions for internal cylindrical grinding machines with horizontal spindle -- Testing of accuracy
ISO 2407:1997/Amd 1:2016 Test conditions for internal cylindrical grinding machines with horizontal spindle -- Testing of accuracy
ISO 2423:1982 Acceptance conditions for radial drilling machines with the arm adjustable in height -- Testing of accuracy
ISO 2433:1999 Machine tools -- Test conditions for external cylindrical and universal grinding machines with a movable table -- Testing of accuracy
ISO 2772-1:1973 Test conditions for box type vertical drilling machines -- Testing of the accuracy -- Part 1: Geometrical tests
ISO 2772-2:1974 Test conditions for box type vertical drilling machines -- Testing of the accuracy -- Part 2: Practical test
ISO 2773-1:1973 Test conditions for pillar type vertical drilling machines -- Testing of the accuracy -- Part 1: Geometrical tests
ISO 2773-2:1973 Test conditions for pillar type vertical drilling machines -- Testing of the accuracy -- Part 2: Practical test
ISO 3070-1:2007 Machine tools -- Test conditions for testing the accuracy of boring and milling machines with horizontal spindle -- Part 1: Machines with fixed column and movable table
ISO 3070-2:2016 Machine tools -- Test conditions for testing the accuracy of boring and milling machines with horizontal spindle -- Part 2: Machines with movable column along the X-axis (floor type)
ISO 3070-3:2007 Machine tools -- Test conditions for testing the accuracy of boring and milling machines with horizontal spindle -- Part 3: Machines with movable column and movable table
ISO 3190:1975 Test conditions for turret and single spindle co-ordinate drilling machines with vertical spindle -- Testing of the accuracy
ISO 3655:1986 Acceptance conditions for vertical turning and boring lathes with one or two columns and a single fixed or movable table -- General introduction and testing of the accuracy
ISO 3686-1:2000 Test conditions for high accuracy turret and single spindle coordinate drilling and boring machines with table of fixed height with vertical spindle -- Testing of the accuracy -- Part 1: Single column type machines
ISO 3686-2:2000 Test conditions for high accuracy turret and single spindle coordinate drilling and boring machines with table of fixed height with vertical spindle -- Testing of the accuracy -- Part 2: Portal type machines with moving table
ISO 3875:2004 Test conditions for surface grinding machines with two columns -- Machines for grinding slideways -- Testing of the accuracy
ISO 4703:2001 Machine tools -- Test conditions for external cylindrical centreless grinding machines -- Testing of the accuracy
ISO 5734:1986 Acceptance conditions of mechanical dividing heads for machine tools -- Testing of accuracy
ISO 6155:1998 Machine tools -- Test conditions for horizontal spindle turret and single spindle automatic lathes -- Testing of the accuracy
ISO 6480:1983 Conditions of acceptance for horizontal internal broaching machines -- Testing of the accuracy
ISO 6481:1981 Acceptance conditions for vertical surface type broaching machines -- Testing of accuracy
ISO 6545:1992 Acceptance conditions for gear hobbing machines -- Testing of the accuracy
ISO 6779:1981 Acceptance conditions for broaching machines of vertical internal type -- Testing of accuracy
ISO 8636-1:2000 Machine tools -- Test conditions for bridge-type milling machines -- Testing of the accuracy -- Part 1: Fixed bridge (portal-type) machines
ISO 8636-2:2007 Machine tools -- Test conditions for bridge-type milling machines -- Testing of the accuracy -- Part 2: Travelling bridge (gantry-type) machines
ISO 8956:1986 Acceptance conditions for copying attachments* integral or otherwise* for lathes -- Testing of the accuracy
ISO 10791-1:2015 Test conditions for machining centres -- Part 1: Geometric tests for machines with horizontal spindle (horizontal Z-axis)
ISO 10791-2:2001 Test conditions for machining centres -- Part 2: Geometric tests for machines with vertical spindle or universal heads with vertical primary rotary axis (vertical Z-axis)
ISO 10791-3:1998 Test conditions for machining centres -- Part 3: Geometric tests for machines with integral indexable or continuous universal heads (vertical Z -axis)
ISO 10791-3:1998/Cor 1:1999 Test conditions for machining centres -- Part 3: Geometric tests for machines with integral indexable or continuous universal heads (vertical Z -axis)
ISO 10791-4:1998 Test conditions for machining centres -- Part 4: Accuracy and repeatability of positioning of linear and rotary axes
ISO 10791-5:1998 Test conditions for machining centres -- Part 5: Accuracy and repeatability of positioning of work-holding pallets
ISO 10791-6:2014 Test conditions for machining centres -- Part 6: Accuracy of speeds and interpolations
ISO 10791-7:2014 Test conditions for machining centres -- Part 7: Accuracy of finished test pieces
ISO 10791-8:2001 Test conditions for machining centres -- Part 8: Evaluation of contouring performance in the three coordinate planes
ISO 10791-9:2001 Test conditions for machining centres -- Part 9: Evaluation of the operating times of tool change and pallet change
ISO 10791-10:2007 Test conditions for machining centres -- Part 10: Evaluation of thermal distortions
ISO 11090-1:2014 Test conditions for die sinking electro-discharge machines (die sinking EDM) -- Testing of the accuracy -- Part 1: Single-column machines (cross-slide table type and fixed-table type)
ISO 11090-2:2014 Test conditions for die sinking electro-discharge machines (die sinking EDM) -- Testing of the accuracy -- Part 2: Double-column machines (slide-head type)
ISO 13041-1:2004 Test conditions for numerically controlled turning machines and turning centres -- Part 1: Geometric tests for machines with a horizontal workholding spindle
ISO 13041-2:2008 Test conditions for numerically controlled turning machines and turning centres -- Part 2: Geometric tests for machines with a vertical workholding spindle
ISO 13041-3:2009 Test conditions for numerically controlled turning machines and turning centres -- Part 3: Geometric tests for machines with inverted vertical workholding spindles
ISO 13041-4:2004 Test conditions for numerically controlled turning machines and turning centres -- Part 4: Accuracy and repeatability of positioning of linear and rotary axes
ISO 13041-5:2015 Test conditions for numerically controlled turning machines and turning centres -- Part 5: Accuracy of speeds and interpolations
ISO 13041-6:2009 Test conditions for numerically controlled turning machines and turning centres -- Part 6: Accuracy of a finished test piece
ISO 13041-7:2004 Test conditions for numerically controlled turning machines and turning centres -- Part 7: Evaluation of contouring performance in the coordinate planes
ISO 13041-8:2004 Test conditions for numerically controlled turning machines and turning centres -- Part 8: Evaluation of thermal distortions
ISO 14137:2015 Test conditions for wire electrical-discharge machines (wire EDM) -- Testing of the accuracy
ISO/TR 16907:2015 Machine tools -- Numerical compensation of geometric errors
ISO/TR 17243-1:2014 Machine tool spindles -- Evaluation of machine tool spindle vibrations by measurements on spindle housing -- Part 1: Spindles with rolling element bearings and integral drives operating at speeds between 600 min-1 and 30 000 min-1
ISO/TR 17243-2:2017 Machine tool spindles -- Evaluation of spindle vibrations by measurements on non-rotating parts -- Part 2: Direct-driven spindles and belt-driven spindles with rolling element bearings operating at speeds between 600 r/min and 30 000 r/min
ISO 26303:2012 Machine tools -- Short-term capability evaluation of machining processes on metal-cutting machine tools
Woodworking machines
ISO 7006:1981 Woodworking machines -- Diameters of spindles for receiving circular sawblades
ISO 7568:1986 Woodworking machines -- Thickness planing machines with rotary cutterblock for one-side dressing -- Nomenclature and acceptance conditions
ISO 7569:1986 Woodworking machines -- Planing machines for two-* three- or four-side dressing -- Nomenclature and acceptance conditions
ISO 7570:1986 Woodworking machines -- Surface planing and thicknessing machines -- Nomenclature and acceptance conditions
ISO 7571:1986 Woodworking machines -- Surface planing machines with cutterblock for one-side dressing -- Nomenclature and acceptance conditions
ISO 7945:1985 Woodworking machines -- Single spindle boring machines -- Nomenclature and acceptance conditions
ISO 7946:1985 Woodworking machines -- Slot mortising machines -- Nomenclature and acceptance conditions
ISO 7947:1985 Woodworking machines -- Two-* three- and four-side moulding machines -- Nomenclature and acceptance conditions
ISO 7948:1987 Woodworking machines -- Routing machines -- Nomenclature and acceptance conditions
ISO 7949:1985 Woodworking machines -- Veneer pack edge shears -- Nomenclature and acceptance conditions
ISO 7950:1985 Woodworking machines -- Single chain mortising machines -- Nomenclature and acceptance conditions
ISO 7957:1987 Woodworking machines -- Radial circular saws -- Nomenclature and acceptance conditions
ISO 7958:1987 Woodworking machines -- Single blade stroke circular sawing machines for lengthwise cutting of solid woods and panels -- Nomenclature and acceptance conditions
ISO 7959:1987 Woodworking machines -- Double edging precision circular sawing machines -- Nomenclature and acceptance conditions
ISO 7983:1988 Woodworking machines -- Single blade circular sawing machines with travelling table -- Nomenclature and acceptance conditions
ISO 7984:1988 Woodworking machines -- Technical classification of woodworking machines and auxiliary machines for woodworking
ISO 7987:1985 Woodworking machines -- Turning lathes -- Nomenclature and acceptance conditions
ISO 7988:1988 Woodworking machines -- Double-end tenoning machines -- Nomenclature and acceptance conditions
ISO 9264:1988 Woodworking machines -- Narrow belt sanding machines with sliding table or frame -- Nomenclature
ISO 9265:1988 Woodworking machines -- Multi-spindle boring machines -- Nomenclature
ISO 9266:1988 Woodworking machines -- Universal tool and cutter sharpeners -- Nomenclature
ISO 9267:1988 Woodworking machines -- Bandsaw blade sharpening machines -- Nomenclature
ISO 18217:2015 Safety of woodworking machines -- Edge-banding machines fed by chain(s)
ISO 19085-1:2017 Woodworking machines -- Safety -- Part 1: Common requirements
ISO 19085-2:2017 Woodworking machines -- Safety -- Part 2: Horizontal beam panel circular sawing machines
ISO 19085-5:2017 Woodworking machines -- Safety -- Part 5: Dimension saws
Noise of machine tools
ISO 230-5:2000 Test code for machine tools -- Part 5: Determination of the noise emission
ISO 7960:1995 Airborne noise emitted by machine tools -- Operating conditions for woodworking machines
ISO 8525:2008 Airborne noise emitted by machine tools -- Operating conditions for metal-cutting machines
Work holding spindles and chucks
ISO 702-1:2009 Machine tools -- Connecting dimensions of spindle noses and work holding chucks -- Part 1: Conical connection
ISO 702-2:2007 Machine tools -- Connecting dimensions of spindle noses and work holding chucks -- Part 2: Camlock type
ISO 702-2:2007/Cor 1:2009 Machine tools -- Connecting dimensions of spindle noses and work holding chucks -- Part 2: Camlock type
ISO 702-3:2007 Machine tools -- Connecting dimensions of spindle noses and work holding chucks -- Part 3: Bayonet type
ISO 702-4:2004 Machine tools -- Connecting dimensions of spindle noses and work holding chucks -- Part 4: Cylindrical connection
ISO 3089:2005 Machine tools -- Test conditions for self-centring* manually operated chucks with one-piece jaws
ISO 3442-1:2005 Machine tools -- Dimensions and geometric tests for self-centring chucks with two-piece jaws -- Part 1: Manually operated chucks with tongue and groove type jaws
ISO 3442-2:2005 Machine tools -- Dimensions and geometric tests for self-centring chucks with two-piece jaws -- Part 2: Power-operated chucks with tongue and groove type jaws
ISO 3442-3:2007 Machine tools -- Dimensions and geometric tests for self-centring chucks with two-piece jaws -- Part 3: Power-operated chucks with serrated jaws
ISO 16156:2004 Machine-tools safety -- Safety requirements for the design and construction of work holding chucks
ISO 19719:2010 Machine tools -- Work holding chucks -- Vocabulary
Safety
ISO 666:2012 Machine tools -- Mounting of grinding wheels by means of hub flanges
ISO 16089:2015 Machine tools -- Safety -- Stationary grinding machines
ISO 16093:2017 Machine tools -- Safety -- Sawing machines for cold metal
ISO/TR 17529:2014 Machine tools -- Practical guidance and example of risk assessment on electro-discharge machines
ISO 23125:2015 Machine tools -- Safety -- Turning machines
ISO 28881:2013 Machine tools -- Safety -- Electro-discharge machines
ISO 28881:2013/Cor 1:2013 Machine tools -- Safety -- Electro-discharge machines
a lot of missing:
