ISO TC 31 STANDARDS
ISO 3877-1:1997 Tyres* valves and tubes -- List of equivalent terms -- Part 1: Tyres
ISO 3877-2:1997 Tyres* valves and tubes -- List of equivalent terms -- Part 2: Tyre valves
ISO 3877-3:1978 Tyres* valves and tubes -- List of equivalent terms -- Part 3: Tubes
ISO 3877-4:1984 Tyres* valves and tubes -- List of equivalent terms -- Part 4: Solid tyres
ISO 4223-1:2002 Definitions of some terms used in the tyre industry -- Part 1: Pneumatic tyres
ISO 4223-1:2002/Amd 1:2011 Definitions of some terms used in the tyre industry -- Part 1: Pneumatic tyres
ISO 4223-2:1991 Definitions of some terms used in the tyre industry -- Part 2: Solid tyres
ISO 13325:2003 Tyres -- Coast-by methods for measurement of tyre-to-road sound emission
ISO 13326:1998 Test methods for measuring tyre uniformity
ISO 15222:2011 Truck and bus tyres -- Method for measuring relative wet grip performance -- Loaded new tyres
ISO/TR 16377:2012 Further clarification of ISO 28580
ISO 16392:2017 Tyres -- Electrical resistance -- Test method for measuring electrical resistance of tyres on a test rig
ISO 17464:2016 Pneumatic tubes for automotive vehicles -- Technical requirements and test methods
ISO 18106:2016 Passenger car* commercial vehicle* truck and bus tyres -- Methods for measuring snow grip performance -- Loaded new tyres
ISO 18164:2005 Passenger car* truck* bus and motorcycle tyres -- Methods of measuring rolling resistance
ISO 23671:2015 Passenger car tyres -- Method for measuring relative wet grip performance -- Loaded new tyres
ISO 28580:2009 Passenger car* truck and bus tyres -- Methods of measuring rolling resistance -- Single point test and correlation of measurement results
ISO/TR 29846:2008 Tyres* valves and tubes -- kPa/psi equivalencies for inflation pressures
Passenger car tyres and rims
ISO 4000-1:2015 Passenger car tyres and rims -- Part 1: Tyres (metric series)
ISO 4000-2:2013 Passenger car tyres and rims -- Part 2: Rims
ISO 10191:2010 Passenger car tyres -- Verifying tyre capabilities -- Laboratory test methods
ISO 16992:2010 Passenger car tyres -- Spare unit substitutive equipment (SUSE)
ISO 17269:2000 Passenger car tyres -- Methods for measuring rolling circumference -- Loaded new tyres
Truck and bus tyres and rims
ISO 4209-1:2001 Truck and bus tyres and rims (metric series) -- Part 1: Tyres
ISO 4209-2:2012 Truck and bus tyres and rims (metric series) -- Part 2: Rims
ISO 9112:2008 Truck and bus tyres -- Methods of measuring tyre rolling circumference -- Loaded new tyres
ISO 10454:1993 Truck and bus tyres -- Verifying tyre capabilities -- Laboratory test methods
Agricultural tyres and rims
ISO 4251-1:2017 Tyres (ply rating marked series) and rims for agricultural tractors and machines -- Part 1: Tyre designation and dimensions* and approved rim contours
ISO 4251-2:2017 Tyres (ply rating marked series) and rims for agricultural tractors and machines -- Part 2: Tyre load ratings
ISO 4251-3:2006 Tyres (ply rating marked series) and rims for agricultural tractors and machines -- Part 3: Rims
ISO 4251-4:2010 Tyres (ply rating marked series) and rims for agricultural tractors and machines -- Part 4: Tyre classification and nomenclature
ISO 4251-5:1992 Tyres (ply rating marked series) and rims for agricultural tractors and machines -- Part 5: Logging and forestry service tyres
ISO 4251-5:1992/Amd 1:1998 Tyres (ply rating marked series) and rims for agricultural tractors and machines -- Part 5: Logging and forestry service tyres
ISO 7867-1:2005 Tyres and rims (metric series) for agricultural tractors and machines -- Part 1: Tyre designation* dimensions and marking* and tyre/rim coordination
ISO 7867-2:2005 Tyres and rims (metric series) for agricultural tractors and machines -- Part 2: Service description and load ratings
ISO 7867-2:2005/Amd 1:2010 Tyres and rims (metric series) for agricultural tractors and machines -- Part 2: Service description and load ratings
ISO 8664:2005 Tyres for agricultural tractors and machines -- Code-designated and service-description marked radial drive-wheel tyres
ISO 8664:2005/Amd 1:2010 Tyres for agricultural tractors and machines -- Code-designated and service-description marked radial drive-wheel tyres
ISO 11795:1997 Agricultural tractor drive wheel tyres -- Method of measuring tyre rolling circumference
ISO 11795:1997/Amd 1:2010 Agricultural tractor drive wheel tyres -- Method of measuring tyre rolling circumference
Off-the-road tyres and rims
ISO 4250-1:2014 Earth-mover tyres and rims -- Part 1: Tyre designation and dimensions
ISO 4250-2:2017 Earth-mover tyres and rims -- Part 2: Loads and inflation pressures
ISO 4250-3:2011 Earth-mover tyres and rims -- Part 3: Rims
ISO 10571:2016 Tyres for mobile cranes and similar specialized machines
ISO 13442:2004 Tyres and rims for construction machines
Industrial tyres and rims
ISO 3739-1:2007 Industrial tyres and rims -- Part 1: Pneumatic tyres (metric series) on 5 degrees tapered or flat base rims -- Designation* dimensions and marking
ISO 3739-2:1992 Industrial tyres and rims -- Part 2: Pneumatic tyres (metric series) on 5 degrees tapered or flat base rims -- Load ratings
ISO 3739-3:2008 Industrial tyres and rims -- Part 3: Rims
ISO 10499-1:1991/Cor 1:1997 Industrial tyres and rims -- Rubber solid tyres (metric series) for pneumatic tyre rims -- Part 1: Designation* dimensions and marking
ISO 10499-1:1991 Industrial tyres and rims -- Rubber solid tyres (metric series) for pneumatic tyre rims -- Part 1: Designation* dimensions and marking
ISO 10499-2:1998 Industrial tyres and rims -- Rubber solid tyres (metric series) for pneumatic tyre rims -- Part 2: Load ratings
ISO 10500:1991 Industrial tyres and rims -- Cylindrical and conical base rubber solid tyres (metric series) -- Designation* dimensions and marking
Aircraft tyres and rims
ISO 3324-1:2013 Aircraft tyres and rims -- Part 1: Specifications
ISO 3324-2:2013 Aircraft tyres and rims -- Part 2: Test methods for tyres
Valves for tube and tubeless tyres
ISO 4570:2002 Tyre valve threads
ISO 7295:1988 Tyre valves for aircraft -- Interchangeability dimensions
ISO 7295:1988/Amd 1:2014 Tyre valves for aircraft -- Interchangeability dimensions
ISO 9413:2012 Tyre valves -- Dimensions and designation
ISO 9413:2012/Amd 1:2012 Tyre valves -- Dimensions and designation
ISO 9475:1994 Aircraft inner tube and tubeless tyre valves -- Cores and caps -- Test methods
ISO 14960-1:2014 Tubeless tyres -- Valves and components -- Part 1: Test methods
ISO 14960-2:2014 Tubeless tyres -- Valves and components -- Part 2: Clamp-in tubeless tyre valve-test method
ISO 18885-1:2017 TPMS snap-in valves -- Part 1: Identification
ISO 20562:2014 Tyre valves -- ISO core chambers No. 1* No. 2* No. 3 and No. 4
Cycle* moped* motorcycle tyres and rims
ISO 4249-1:1985 Motorcycle tyres and rims (Code-designated series) -- Part 1: Tyres
ISO 4249-2:1990 Motorcycle tyres and rims (Code-designated series) -- Part 2: Tyre load ratings
ISO 4249-3:2010 Motorcycle tyres and rims (code-designated series) -- Part 3: Rims
ISO 5751-1:2010 Motorcycle tyres and rims (metric series) -- Part 1: Design guides
ISO 5751-2:2010 Motorcycle tyres and rims (metric series) -- Part 2: Tyre dimensions and load-carrying capacities
ISO 5751-3:2010 Motorcycle tyres and rims (metric series) -- Part 3: Range of approved rim contours
ISO 5775-1:2014 Bicycle tyres and rims -- Part 1: Tyre designations and dimensions
ISO 5775-2:2015 Bicycle tyres and rims -- Part 2: Rims
ISO 6054-1:1994 Motorcycle tyres and rims (Code-designated series) -- Diameter codes 4 to 12 -- Part 1: Tyres
ISO 6054-2:1990 Motorcycle tyres and rims (Code-designated series) -- Diameter codes 4 to 12 -- Part 2: Rims
ISO 10231:2003 Motorcycle tyres -- Test methods for verifying tyre capabilities
ISO 10231:2003/Amd 1:2015 Motorcycle tyres -- Test methods for verifying tyre capabilities
ISO 13328:2000 Motorcycle tyres -- Measurement of tyre rolling circumference -- Loaded new tyres
ISO 29802:2017 All-terrain (AT) tyres and rims -- Symbol marked pneumatic tyres on 5 degree tapered rims -- Designation* dimension* marking and load ratings
missing are:
