[B]ISO TC 48 standards[B]
ISO 383:1976 Laboratory glassware -- Interchangeable conical ground joints
ISO 384:2015 Laboratory glass and plastics ware -- Principles of design and construction of volumetric instruments
ISO 385:2005 Laboratory glassware -- Burettes
ISO 386:1977 Liquid-in-glass laboratory thermometers -- Principles of design* construction and use
ISO 641:1975 Laboratory glassware -- Interchangeable spherical ground joints
ISO 648:2008 Laboratory glassware -- Single-volume pipettes
ISO 651:1975 Solid-stem calorimeter thermometers
ISO 652:1975 Enclosed-scale calorimeter thermometers
ISO 653:1980 Long solid-stem thermometers for precision use
ISO 654:1980 Short solid-stem thermometers for precision use
ISO 655:1980 Long enclosed-scale thermometers for precision use
ISO 656:1980 Short enclosed-scale thermometers for precision use
ISO 835:2007 Laboratory glassware -- Graduated pipettes
ISO 1042:1998 Laboratory glassware -- One-mark volumetric flasks
ISO 1769:1975 Laboratory glassware -- Pipettes -- Colour coding
ISO 1770:1981 Solid-stem general purpose thermometers
ISO 1770:1981/Amd 1:1983 Solid-stem general purpose thermometers
ISO 1771:1981 Enclosed-scale general purpose thermometers
ISO 1771:1981/Amd 1:1983 Enclosed-scale general purpose thermometers
ISO 1772:1975 Laboratory crucibles in porcelain and silica
ISO 1773:1997 Laboratory glassware -- Narrow-necked boiling flasks
ISO 1775:1975 Porcelain laboratory apparatus -- Requirements and methods of test
ISO 3819:2015 Laboratory glassware -- Beakers
ISO 4142:2002 Laboratory glassware -- Test tubes
ISO 4785:1997 Laboratory glassware -- Straight-bore glass stopcocks for general purposes
ISO 4786:1977 Enclosed-scale adjustable-range thermometers
ISO 4787:2010 Laboratory glassware -- Volumetric instruments -- Methods for testing of capacity and for use
ISO 4788:2005 Laboratory glassware -- Graduated measuring cylinders
ISO 4791-1:1985 Laboratory apparatus -- Vocabulary relating to apparatus made essentially from glass* porcelain or vitreous silica -- Part 1: Names for items of apparatus
ISO 4793:1980 Laboratory sintered (fritted) filters -- Porosity grading* classification and designation
ISO 4796-1:2016 Laboratory glassware -- Bottles -- Part 1: Screw-neck bottles
ISO 4796-2:2000 Laboratory glassware -- Bottles -- Part 2: Conical neck bottles
ISO 4796-3:2000 Laboratory glassware -- Bottles -- Part 3: Aspirator bottles
ISO 4797:2015 Laboratory glassware -- Boiling flasks with conical ground joints
ISO 4798:1997 Laboratory glassware -- Filter funnels
ISO 4799:1978 Laboratory glassware -- Condensers
ISO 4800:1998 Laboratory glassware -- Separating funnels and dropping funnels
ISO 4801:1979 Glass alcoholometers and alcohol hydrometers not incorporating a thermometer
ISO 4803:1978 Laboratory glassware -- Borosilicate glass tubing
ISO 6556:2012 Laboratory glassware -- Filter flasks
ISO 6706:1981 Plastics laboratory ware -- Graduated measuring cylinders
ISO 7056:1981 Plastics laboratory ware -- Beakers
ISO 7057:1981 Plastics laboratory ware -- Filter funnels
ISO 7550:1985 Laboratory glassware -- Disposable micropipettes
ISO 7712:1983 Laboratory glassware -- Disposable Pasteur pipettes
ISO 7713:1985 Laboratory glassware -- Disposable serological pipettes
ISO 8655-1:2002 Piston-operated volumetric apparatus -- Part 1: Terminology* general requirements and user recommendations
ISO 8655-1:2002/Cor 1:2008 Piston-operated volumetric apparatus -- Part 1: Terminology* general requirements and user recommendations
ISO 8655-2:2002 Piston-operated volumetric apparatus -- Part 2: Piston pipettes
ISO 8655-2:2002/Cor 1:2008 Piston-operated volumetric apparatus -- Part 2: Piston pipettes
ISO 8655-3:2002 Piston-operated volumetric apparatus -- Part 3: Piston burettes
ISO 8655-3:2002/Cor 1:2008 Piston-operated volumetric apparatus -- Part 3: Piston burettes
ISO 8655-4:2002 Piston-operated volumetric apparatus -- Part 4: Dilutors
ISO 8655-4:2002/Cor 1:2008 Piston-operated volumetric apparatus -- Part 4: Dilutors
ISO 8655-5:2002 Piston-operated volumetric apparatus -- Part 5: Dispensers
ISO 8655-5:2002/Cor 1:2008 Piston-operated volumetric apparatus -- Part 5: Dispensers
ISO 8655-6:2002 Piston-operated volumetric apparatus -- Part 6: Gravimetric methods for the determination of measurement error
ISO 8655-6:2002/Cor 1:2008 Piston-operated volumetric apparatus -- Part 6: Gravimetric methods for the determination of measurement error
ISO 8655-7:2005 Piston-operated volumetric apparatus -- Part 7: Non-gravimetric methods for the assessment of equipment performance
ISO 8655-7:2005/Cor 1:2008 Piston-operated volumetric apparatus -- Part 7: Non-gravimetric methods for the assessment of equipment performance
ISO 10991:2009 Micro process engineering -- Vocabulary
ISO 12771:1997 Plastics laboratory ware -- Disposable serological pipettes
ISO 12772:1997 Laboratory glassware -- Disposable microhaematocrit capillary tubes
ISO 13079:2011 Laboratory glass and plastics ware -- Tubes for the measurement of the erythrocyte sedimentation rate by the Westergren method
ISO 13130:2011 Laboratory glassware -- Desiccators
ISO 13132:2011 Laboratory glassware -- Petri dishes
ISO/TR 16153:2004 Piston-operated volumetric instruments -- Determination of uncertainty for volume measurements made using the photometric method
ISO 16496:2016 Laboratory glassware -- Vacuum-jacketed vessels for heat insulation
ISO/TR 20461:2000 Determination of uncertainty for volume measurements made using the gravimetric method
ISO/TR 20461:2000/Cor 1:2008 Determination of uncertainty for volume measurements made using the gravimetric method
ISO 24450:2005 Laboratory glassware -- Wide-necked boiling flasks
ISO 24998:2008 Plastics laboratory ware -- Single-use Petri dishes for microbiological procedures
Thermometers
ISO 4795:1996 Glass for thermometer bulbs
ISO 6152:1982 Thermometers for use with alcoholometers and alcohol hydrometers
Density measuring instruments
ISO 387:1977 Hydrometers -- Principles of construction and adjustment
ISO 649-1:1981 Laboratory glassware -- Density hydrometers for general purposes -- Part 1: Specification
ISO 649-2:1981 Laboratory glassware -- Density hydrometers for general purposes -- Part 2: Test methods and use
ISO 650:1977 Relative density 60/60 degrees F hydrometers for general purposes
ISO 1768:1975 Glass hydrometers -- Conventional value for the thermal cubic expansion coefficient (for use in the preparation of measurement tables for liquids)
ISO 3507:1999 Laboratory glassware -- Pyknometers
ISO 4805:1982 Laboratory glassware -- Thermo-alcoholometers and alcohol-thermohydrometers
ISO 15212-1:1998 Oscillation-type density meters -- Part 1: Laboratory instruments
ISO 15212-1:1998/Cor 1:2008 Oscillation-type density meters -- Part 1: Laboratory instruments
ISO 15212-2:2002 Oscillation-type density meters -- Part 2: Process instruments for homogeneous liquids
ISO 15212-2:2002/Cor 1:2008 Oscillation-type density meters -- Part 2: Process instruments for homogeneous liquids
Quality of glassware
ISO 695:1991 Glass -- Resistance to attack by a boiling aqueous solution of mixed alkali -- Method of test and classification
ISO 718:1990 Laboratory glassware -- Thermal shock and thermal shock endurance -- Test methods
ISO 1776:1985 Glass -- Resistance to attack by hydrochloric acid at 100 degrees C -- Flame emission or flame atomic absorption spectrometric method
ISO 3585:1998 Borosilicate glass 3.3 -- Properties
ISO 4790:1992 Glass-to-glass sealings -- Determination of stresses
ISO 4794:1982 Laboratory glassware -- Methods for assessing the chemical resistance of enamels used for colour coding and colour marking
ISO 7884-1:1987 Glass -- Viscosity and viscometric fixed points -- Part 1: Principles for determining viscosity and viscometric fixed points
ISO 7884-2:1987 Glass -- Viscosity and viscometric fixed points -- Part 2: Determination of viscosity by rotation viscometers
ISO 7884-3:1987 Glass -- Viscosity and viscometric fixed points -- Part 3: Determination of viscosity by fibre elongation viscometer
ISO 7884-4:1987 Glass -- Viscosity and viscometric fixed points -- Part 4: Determination of viscosity by beam bending
ISO 7884-5:1987 Glass -- Viscosity and viscometric fixed points -- Part 5: Determination of working point by sinking bar viscometer
ISO 7884-6:1987 Glass -- Viscosity and viscometric fixed points -- Part 6: Determination of softening point
ISO 7884-7:1987 Glass -- Viscosity and viscometric fixed points -- Part 7: Determination of annealing point and strain point by beam bending
ISO 7884-8:1987 Glass -- Viscosity and viscometric fixed points -- Part 8: Determination of (dilatometric) transformation temperature
ISO 7991:1987 Glass -- Determination of coefficient of mean linear thermal expansion
ISO 10136-1:1993 Glass and glassware -- Analysis of extract solutions -- Part 1: Determination of silicon dioxide by molecular absorption spectrometry
ISO 10136-2:1993 Glass and glassware -- Analysis of extract solutions -- Part 2: Determination of sodium oxide and potassium oxide by flame spectrometric methods
ISO 10136-3:1993 Glass and glasssware -- Analysis of extract solutions -- Part 3: Determination of calcium oxide and magnesium oxide by flame atomic absorption spectrometry
ISO 10136-4:1993 Glass and glassware -- Analysis of extract solutions -- Part 4: Determination of aluminium oxide by molecular absorption spectrometry
ISO 10136-5:1993 Glass and glassware -- Analysis of extract solutions -- Part 5: Determination of iron(III) oxide by molecular absorption spectrometry and flame atomic absorption spectrometry
ISO 10136-6:1993 Glass and glassware -- Analysis of extract solutions -- Part 6: Determination of boron(III) oxide by molecular absorption spectrometry
ISO 10345-1:1992 Glass -- Determination of stress-optical coefficient -- Part 1: Tensile test
ISO 10345-2:1992 Glass -- Determination of stress-optical coefficient -- Part 2: Bending test
ISO 12775:1997 Guidelines on types of glass of normal bulk-production composition and their test methods
the missing are:
