Thread: ISO Collection 154/300:ISO TC 92- Fire Safety
    ISO/TC 92 STANDARDS
    ISO 13943:2008 Fire safety -- Vocabulary
    ISO/TR 17755:2014 Fire safety -- Overview of national fire statistics practices
    Fire initiation and growth
    ISO 1182:2010 Reaction to fire tests for products -- Non-combustibility test
    ISO 1716:2010 Reaction to fire tests for products -- Determination of the gross heat of combustion (calorific value)
    ISO/TS 3814:2014 Standard tests for measuring reaction-to-fire of products and materials -- Their development and application
    ISO 5657:1997 Reaction to fire tests -- Ignitability of building products using a radiant heat source
    ISO/TS 5658-1:2006 Reaction to fire tests -- Spread of flame -- Part 1: Guidance on flame spread
    ISO 5658-2:2006 Reaction to fire tests -- Spread of flame -- Part 2: Lateral spread on building and transport products in vertical configuration
    ISO 5658-2:2006/Amd 1:2011 Reaction to fire tests -- Spread of flame -- Part 2: Lateral spread on building and transport products in vertical configuration
    ISO 5658-4:2001 Reaction to fire tests -- Spread of flame -- Part 4: Intermediate-scale test of vertical spread of flame with vertically oriented specimen
    ISO 5660-1:2015 Reaction-to-fire tests -- Heat release* smoke production and mass loss rate -- Part 1: Heat release rate (cone calorimeter method) and smoke production rate (dynamic measurement)
    ISO/TS 5660-3:2012 Reaction-to-fire tests -- Heat release* smoke production and mass loss rate -- Part 3: Guidance on measurement
    ISO/TS 5660-4:2016 Reaction-to-fire tests -- Heat release* smoke production and mass loss rate -- Part 4: Measurement of low levels of heat release
    ISO 9239-1:2010 Reaction to fire tests for floorings -- Part 1: Determination of the burning behaviour using a radiant heat source
    ISO 9239-2:2002 Reaction to fire tests for floorings -- Part 2: Determination of flame spread at a heat flux level of 25 kW/m2
    ISO 9705-1:2016 Reaction to fire tests -- Room corner test for wall and ceiling lining products -- Part 1: Test method for a small room configuration
    ISO/TR 9705-2:2001 Reaction-to-fire tests -- Full-scale room tests for surface products -- Part 2: Technical background and guidance
    ISO/TR 11696-1:1999 Uses of reaction to fire test results -- Part 1: Application of test results to predict fire performance of internal linings and other building products
    ISO/TR 11696-2:1999 Uses of reaction to fire test results -- Part 2: Fire hazard assessment of construction products
    ISO/TR 11925-1:1999 Reaction to fire tests -- Ignitability of building products subjected to direct impingement of flame -- Part 1: Guidance on ignitability
    ISO 11925-2:2010 Reaction to fire tests -- Ignitability of products subjected to direct impingement of flame -- Part 2: Single-flame source test
    ISO 11925-2:2010/Cor 1:2011 Reaction to fire tests -- Ignitability of products subjected to direct impingement of flame -- Part 2: Single-flame source test
    ISO 11925-3:1997 Reaction to fire tests -- Ignitability of building products subjected to direct impingement of flame -- Part 3: Multi-source test
    ISO 11925-3:1997/Cor 1:1998 Reaction to fire tests -- Ignitability of building products subjected to direct impingement of flame -- Part 3: Multi-source test
    ISO 12136:2011 Reaction to fire tests -- Measurement of material properties using a fire propagation apparatus
    ISO 12863:2010 Standard test method for assessing the ignition propensity of cigarettes
    ISO 12863:2010/Amd 1:2016 Standard test method for assessing the ignition propensity of cigarettes
    ISO 12863:2010/Cor 1:2011 Standard test method for assessing the ignition propensity of cigarettes
    ISO 12949:2011 Standard test method for measuring the heat release rate of low flammability mattresses and mattress sets
    ISO 13784-1:2014 Reaction to fire test for sandwich panel building systems -- Part 1: Small room test
    ISO 13784-2:2002 Reaction-to-fire tests for sandwich panel building systems -- Part 2: Test method for large rooms
    ISO 13785-1:2002 Reaction-to-fire tests for façades -- Part 1: Intermediate-scale test
    ISO 13785-2:2002 Reaction-to-fire tests for façades -- Part 2: Large-scale test
    ISO 14696:2009 Reaction-to-fire tests -- Determination of fire and thermal parameters of materials* products and assemblies using an intermediate-scale calorimeter (ICAL)
    ISO 14697:2007 Reaction-to-fire tests -- Guidance on the choice of substrates for building and transport products
    ISO 14934-1:2010 Fire tests -- Calibration and use of heat flux meters -- Part 1: General principles
    ISO 14934-2:2013 Fire tests -- Calibration and use of heat flux meters -- Part 2: Primary calibration methods
    ISO 14934-3:2012 Fire tests -- Calibration and use of heat flux meters -- Part 3: Secondary calibration method
    ISO 14934-4:2014 Fire tests -- Calibration and use of heat flux meters -- Part 4: Guidance on the use of heat flux meters in fire tests
    ISO 16405:2015 Room corner and open calorimeter -- Guidance on sampling and measurement of effluent gas production using FTIR technique
    ISO/TR 17252:2008 Fire tests -- Applicability of reaction to fire tests to fire modelling and fire safety engineering
    ISO/TS 17431:2006 Fire tests-- Reduced-scale model box test
    ISO 17554:2014 Reaction to fire tests -- Mass loss measurement
    ISO 20632:2008 Reaction-to-fire tests -- Small room test for pipe insulation products or systems
    ISO/TS 22269:2005 Reaction to fire tests -- Fire growth -- Full-scale test for stairs and stair coverings
    ISO 24473:2008 Fire tests -- Open calorimetry -- Measurement of the rate of production of heat and combustion products for fires of up to 40 MW
    ISO 29473:2010 Fire tests -- Uncertainty of measurements in fire tests
    Fire containment
    ISO 834-1:1999 Fire-resistance tests -- Elements of building construction -- Part 1: General requirements
    ISO 834-1:1999/Amd 1:2012 Fire-resistance tests -- Elements of building construction -- Part 1: General requirements
    ISO/TR 834-2:2009 Fire-resistance tests -- Elements of building construction -- Part 2: Guidance on measuring uniformity of furnace exposure on test samples
    ISO/TR 834-3:2012 Fire-resistance tests -- Elements of building construction -- Part 3: Commentary on test method and guide to the application of the outputs from the fire-resistance test
    ISO 834-4:2000 Fire-resistance tests -- Elements of building construction -- Part 4: Specific requirements for loadbearing vertical separating elements
    ISO 834-5:2000 Fire-resistance tests -- Elements of building construction -- Part 5: Specific requirements for loadbearing horizontal separating elements
    ISO 834-6:2000 Fire-resistance tests -- Elements of building construction -- Part 6: Specific requirements for beams
    ISO 834-7:2000 Fire-resistance tests -- Elements of building construction -- Part 7: Specific requirements for columns
    ISO 834-8:2002 Fire-resistance tests -- Elements of building construction -- Part 8: Specific requirements for non-loadbearing vertical separating elements
    ISO 834-8:2002/Cor 1:2009 Fire-resistance tests -- Elements of building construction -- Part 8: Specific requirements for non-loadbearing vertical separating elements
    ISO 834-9:2003 Fire-resistance tests -- Elements of building construction -- Part 9: Specific requirements for non-loadbearing ceiling elements
    ISO 834-9:2003/Cor 1:2009 Fire-resistance tests -- Elements of building construction -- Part 9: Specific requirements for non-loadbearing ceiling elements
    ISO 834-10:2014 Fire resistance tests -- Elements of building construction -- Part 10: Specific requirements to determine the contribution of applied fire protection materials to structural steel elements
    ISO 834-11:2014 Fire resistance tests -- Elements of building construction -- Part 11: Specific requirements for the assessment of fire protection to structural steel elements
    ISO 834-12:2012 Fire resistance tests -- Elements of building construction -- Part 12: Specific requirements for separating elements evaluated on less than full scale furnaces
    ISO 3008-2:2017 Fire-resistance tests -- Part 2: Lift landing door assemblies
    ISO 3008-3:2016 Fire resistance tests -- Part 3: Door and shutter assemblies horizontally oriented
    ISO 3008:2007 Fire-resistance tests -- Door and shutter assemblies
    ISO 3009:2003 Fire-resistance tests -- Elements of building construction -- Glazed elements
    ISO 5925-1:2007 Fire tests -- Smoke-control door and shutter assemblies -- Part 1: Ambient- and medium-temperature leakage tests
    ISO 5925-1:2007/Amd 1:2015 Fire tests -- Smoke-control door and shutter assemblies -- Part 1: Ambient- and medium-temperature leakage tests
    ISO/TR 5925-2:2006 Fire tests -- Smoke-control door and shutter assemblies -- Part 2: Commentary on test method and the applicability of test conditions and the use of test data in a smoke containment strategy
    ISO 6944-1:2008 Fire containment -- Elements of building construction -- Part 1: Ventilation ducts
    ISO 6944-1:2008/Amd 1:2015 Fire containment -- Elements of building construction -- Part 1: Ventilation ducts
    ISO 6944-2:2009 Fire containment -- Elements of building construction -- Part 2: Kitchen extract ducts
    ISO 10294-1:1996 Fire resistance tests -- Fire dampers for air distribution systems -- Part 1: Test method
    ISO 10294-1:1996/Amd 1:2014 Fire resistance tests -- Fire dampers for air distribution systems -- Part 1: Test method
    ISO 10294-2:1999 Fire resistance tests -- Fire dampers for air distribution systems -- Part 2: Classification* criteria and field of application of test results
    ISO 10294-3:1999 Fire resistance tests -- Fire dampers for air distribution systems -- Part 3: Guidance on the test method
    ISO 10294-4:2001 Fire resistance tests -- Fire dampers for air distribution systems -- Part 4: Test of thermal release mechanism
    ISO 10294-4:2001/Amd 1:2014 Specific performance requirement for thermal release mechanism based upon performance of thermal release mechanism used in ISO 10294-1 test specimen
    ISO 10294-5:2005 Fire resistance tests -- Fire dampers for air distribution systems -- Part 5: Intumescent fire dampers
    ISO 10295-1:2007 Fire tests for building elements and components -- Fire testing of service installations -- Part 1: Penetration seals
    ISO 10295-2:2009 Fire tests for building elements and components -- Fire testing of service installations -- Part 2: Linear joint (gap) seals
    ISO 10295-2:2009/Cor 1:2009 Fire tests for building elements and components -- Fire testing of service installations -- Part 2: Linear joint (gap) seals
    ISO/TR 10295-3:2012 Fire tests for building elements and components -- Fire testing of service installations -- Part 3: Single component penetration seals -- Guidance on the construction and use of test configurations and simulated services to characterise sealing materials
    ISO 12468-1:2013 External exposure of roofs to fire -- Part 1: Test method
    ISO 12468-2:2013 External exposure of roofs to fire -- Part 2: Classification of roofs
    ISO/TR 12468-3:2014 External exposure of roofs to fire -- Part 3: Commentary
    ISO/TR 12471:2004 Computational structural fire design -- Review of calculation models* fire tests for determining input material data and needs for further development
    ISO 12472:2003 Fire resistance of timber door assemblies - Method of determining the efficacy of intumescent seals
    ISO/TR 15655:2003 Fire resistance -- Tests for thermo-physical and mechanical properties of structural materials at elevated temperatures for fire engineering design
    ISO/TR 15656:2003 Fire resistance -- Guidelines for evaluating the predictive capability of calculation models for structural fire behaviour
    ISO/TR 15657:2013 Fire resistance tests -- Guidelines for computational structural fire design
    ISO/TR 15658:2009 Fire resistance tests -- Guidelines for the design and conduct of non-furnace-based large-scale tests and simulation
    ISO/TR 22898:2006 Review of outputs for fire containment tests for buildings in the context of fire safety engineering
    ISO 22899-1:2007 Determination of the resistance to jet fires of passive fire protection materials -- Part 1: General requirements
    ISO/TR 22899-2:2013 Determination of the resistance to jet fires of passive fire protection -- Part 2: Guidance on classification and implementation methods
    Fire threat to people and environment
    ISO 12828-1:2011 Validation method for fire gas analysis -- Part 1: Limits of detection and quantification
    ISO 12828-2:2016 Validation methods for fire gas analyses -- Part 2: Intralaboratory validation of quantification methods
    ISO 13344:2015 Estimation of the lethal toxic potency of fire effluents
    ISO 13571:2012 Life-threatening components of fire -- Guidelines for the estimation of time to compromised tenability in fires
    ISO/TR 13571-2:2016 Life-threatening components of fire -- Part 2: Methodology and examples of tenability assessment
    ISO 16312-1:2016 Guidance for assessing the validity of physical fire models for obtaining fire effluent toxicity data for fire hazard and risk assessment -- Part 1: Criteria
    ISO/TR 16312-2:2007 Guidance for assessing the validity of physical fire models for obtaining fire effluent toxicity data for fire hazard and risk assessment -- Part 2: Evaluation of individual physical fire models
    ISO/TS 19700:2016 Controlled equivalence ratio method for the determination of hazardous components of fire effluents -- Steady-state tube furnace
    ISO 19701:2013 Methods for sampling and analysis of fire effluents
    ISO 19702:2015 Guidance for sampling and analysis of toxic gases and vapours in fire effluents using Fourier Transform Infrared (FTIR) spectroscopy
    ISO 19703:2010 Generation and analysis of toxic gases in fire -- Calculation of species yields* equivalence ratios and combustion efficiency in experimental fires
    ISO 19706:2011 Guidelines for assessing the fire threat to people
    ISO 26367-1:2011 Guidelines for assessing the adverse environmental impact of fire effluents -- Part 1: General
    ISO 26367-2:2017 Guidelines for assessing the adverse environmental impact of fire effluents -- Part 2: Methodology for compiling data on environmentally significant emissions from fires
    ISO/TR 26368:2012 Environmental damage limitation from fire-fighting water run-off
    ISO 27368:2008 Analysis of blood for asphyxiant toxicants -- Carbon monoxide and hydrogen cyanide
    ISO 29903:2012 Guidance for comparison of toxic gas data between different physical fire models and scales
    ISO 29904:2013 Fire chemistry -- Generation and measurement of aerosols
    Fire safety engineering
    ISO/TS 13447:2013 Fire safety engineering -- Guidance for use of fire zone models
    ISO/TR 16576:2017 Fire safety engineering -- Examples of fire safety objectives* functional requirements and safety criteria
    ISO 16730-1:2015 Fire safety engineering -- Procedures and requirements for verification and validation of calculation methods -- Part 1: General
    ISO/TR 16730-2:2013 Fire safety engineering -- Assessment* verification and validation of calculation methods -- Part 2: Example of a fire zone model
    ISO/TR 16730-3:2013 Fire safety engineering -- Assessment* verification and validation of calculation methods -- Part 3: Example of a CFD model
    ISO/TR 16730-4:2013 Fire safety engineering -- Assessment* verification and validation of calculation methods -- Part 4: Example of a structural model
    ISO/TR 16730-5:2013 Fire safety engineering -- Assessment* verification and validation of calculation methods -- Part 5: Example of an Egress model
    ISO 16732-1:2012 Fire safety engineering -- Fire risk assessment -- Part 1: General
    ISO/TR 16732-2:2012 Fire Safety Engineering -- Fire risk assessment -- Part 2: Example of an office building
    ISO/TR 16732-3:2013 Fire safety engineering -- Fire risk assessment -- Part 3: Example of an industrial property
    ISO 16733-1:2015 Fire safety engineering -- Selection of design fire scenarios and design fires -- Part 1: Selection of design fire scenarios
    ISO 16734:2006 Fire safety engineering -- Requirements governing algebraic equations -- Fire plumes
    ISO 16735:2006 Fire safety engineering -- Requirements governing algebraic equations -- Smoke layers
    ISO 16736:2006 Fire safety engineering -- Requirements governing algebraic equations -- Ceiling jet flows
    ISO 16737:2012 Fire safety engineering -- Requirements governing algebraic equations -- Vent flows
    ISO/TR 16738:2009 Fire-safety engineering -- Technical information on methods for evaluating behaviour and movement of people
    ISO 23932:2009 Fire safety engineering -- General principles
    ISO 24678-6:2016 Fire safety engineering -- Requirements governing algebraic formulae -- Part 6: Flashover related phenomena
    ISO/TS 24679:2011 Fire safety engineering -- Performance of structures in fire
    ISO/TR 24679-2:2017 Fire safety engineering -- Performance of structure in fire -- Part 2: Example of an airport terminal
    ISO/TR 24679-3:2015 Fire safety engineering -- Performance of structure in fire -- Part 3: Example of an open car park
    ISO/TS 29761:2015 Fire safety engineering -- Selection of design occupant behavioural scenarios
    the missing are:
    Re: ISO Collection 154/300:ISO TC 92- Fire Safety
    Yes* brother! Thanks
  1. CEN Standards Collection 181/370: CEN TC 127-Fire Safety In Buildings
    Last Post: 09-27-2018, 10:44 AM
  2. Fire Safety Books Collection
    By zalam4u in forum Safety And Environment
    Last Post: 06-11-2017, 02:41 AM
  3. CEN Standards Collection 152/370: CEN TC 369-Candle Fire Safety
    Last Post: 05-29-2017, 02:08 AM
  4. Replies: 2
    Last Post: 04-05-2017, 06:19 PM
  5. Replies: 0
    Last Post: 09-29-2014, 11:17 PM
