Thread: realtime hydrocarbons properties with Prode Thermodynamic Server
    we are considering to install Prode Thermodynamic Server
    to work with our Gas Chromatographs to monitor properties such as Cricondentherm* Hydrate Formation Temperature* Water Dew Point etc.
    our DCS can communicate via MODBUS and Prode Server has MODBUS (plus OPC) but errors with MODBUS seem difficult to manage (compared with OPC)*
    we could set a coil or a similar signal (while with OPC we could catch the details)*
    do you have experience with realtime process applications via MODBUS protocol ?
    How do you manage errors ?
    Re: realtime hydrocarbons properties with Prode Thermodynamic Server
    with Prode Thermodynamic Server you can set a specific channel (a boolean) for errors*
    but* yes* there are some limits compared to OPC*
    why don't you switch to OPC (which is supported by Prode Thermodynamic Server) if that looks as better solution to you ?
    thanks*
    the OPC option requires additional DCS card (expensive)*
    anyway* we have solved with MODBUS.
  1. Replies: 12
    Last Post: 07-01-2012, 08:23 PM
  2. Prode Properties in VB NET
    By hans23 in forum Engineering Programming
    Last Post: 09-30-2011, 07:25 PM
  3. Physical Properties of Hydrocarbons: Volume 1 + 2
    By ameer in forum Petroleum Refining
    Last Post: 08-07-2011, 04:51 AM
