In the low temperature, the oil products (for example: lubricant oil) in the tank's viscosity will bring the difficulty to get them form the oil storage tank. How to solve the problem well?
In the market, most of user use the electric heater to heat the oil products in the tank, but it will bring the parts of oil will be over heated, effect the oil product's quality. If you use the coil pipe heat the oil in the tank, if you need get only little oil from the tank, you have to heat whole of the oil in the tank. The oil products will be heated repeatedly, and effect the quality well too.
For solve the problem, our company provide one kind of oil storage tank heater, it use the shell and tube heat exchanger to heat the oil in the tank.
The way is to break the bottom of the oil storage tank, put the heat exchanger into the bottom of the storage tank, the oil is exchanged in the shell side, the steam run in the tube side.
It has the following function
1.High Heating speed, high heat transfer efficiency, Less solid fouling, long useful life, small external size
2.Oil is heated quantificationally. It can heat the oil according to demands.
3.It avoids repeat heating the oil, the oil will not be happened to be over-heated partially and coked, guarantee the oil ‘s chromaticity quality and reduce the oil deposal cost..
4.corrosion resistance, high temperature resistance, high pressure resistance
5.The advanced structure design technique guarantee the oil be able to flow out smoothly and the oil in the bottom will be extracted completely.
6.With the compact structure and convenient installation and maintenance, It will not effect the oil tank’s safety
7.It can control the heating steam’s feed quantity automatically according to the difference of the Oil’s temperature between passing in and out the tank and flow rate of the oil poured.
Now the heater has been used in SINOPEC AND CIPE 's oil storage tank. The next step, we hope to establish the business relations will the other company in the world.
You mey find more details about the products from our web site:
Or download the catalogue from the following web site:
