Dolphins Volts is a multi award winning* electrical design software program which performs branch circuit analysis* dynamic panel layouts* automated panel schedules* conduit and feeder schedules* one-line riser diagrams* voltage drop calculations and various analysis and custom reports. The easy to use data entry and drop down lists increases the efficiency of the design process by automating repetitive and time-consuming tasks. All computations are compliant to IEEE Standard 141 and the 2005 NFPA National Electrical Code. With Dolphins Volts you will experience more accurate results within an intuitive interface that accommodates the requirements of electricians* designers* code inspectors and engineers at all levels of program literacy.
The electrical design process is dynamic* changes are inevitable* and budgets and schedules are constantly changing. Dolphins Volts will let you capitalize on the fast track construction process - the process of design and construction can operate concurrently without sacrificing the quality of the design process as Dolphins Volts accommodates the constant changes of the design process by allowing the investigation of design alternatives. With Dolphins Volts the automation of the electrical design process eliminates the added pressure of time constraints* which would invite errors and make the process increasingly difficult to manage. Dolphins Voltswill minimize staff overloads and overtime requirements.
Dolphins Volts v6.10 + Dolphins Volts v6.10 = link
33 Mb (RAR5* incl. 3% - info for restoration purpose)
Must be loged on lavteam to see and download
