PumpBase finds the best pumps for your fluid conveyance application. You can refine your selection by specifying up to 40 selection criteria. PumpBase's database contains thousands of curves from dozens of participating pump manufacturers. Detailed reports are created that can be submitted to pump manufacturers and sales representative for further application verification and price quotes.
Features:
  • Complete pump curve database access and editing.
  • Communicates with HYDROFLO for system curve development.
  • Quick affinity law conversions for speed and trim.
  • Extensive and editable liquid property database.
  • Automatic viscosity corrections to pump curves.
  • Efficiency and NPSHR curves are plotted on pump graphics.
  • Both English and SI (metric) units.
  • User Project files save all selection information.
  • Technical Bulletins/Dimensional Schematics available.
  • Liquid temperature rise calculations.
Operation:
View all pumps by default. As you add restrictions* the database is filtered for those criteria. Optionally specify operating point data TDH (total dynamic head) and operating flow to select pumps whose operating envelopes include the operating point. Specify NPSHA (Net Positive Suction Head Available) to restrict selection to pumps whose NPSH required is adequate for operation. Specify (or select) liquid property data to obtain pumps that can provide the required flow and TDH. Enter just the pumped liquid properties and view pump curves with viscosity corrections applied. Manual correction factors can be specified and applied to stocks* slurries and other liquids. Specify additional selection criteria such as specific manufacturer* curve key* series/model* speed* 60/50 Hz* max sphere size* pump orientation (horizontal* vertical* in-line* side-suction* end-suction)* application type (fire* well* process* sludge/slurry* dewatering* sewage* wastewater* HVAC)* features (portable* submersible* split-case* solids handling* non AC powered* self-priming* high temperature* high corrosive* ANSI* ISO 2858).
Tahoe Design PumpBase v3.0.1.1 + Tahoe Design PumpBase v3.0.1.1 = link
5 Mb (RAR5* incl. 3% - info for restoration purpose)
[link Point to another website Only the registered members can access] Must be loged on lavteam to see and download
