Results 1 to 1 of 1
Thread: Insight Numerics Detect3D v2.13
    Detect3D is the most accurate and trusted 3D fire and gas mapping tool for the design and assessment of detector layouts. Using the integrated design environment* line-of-sight flame detectors* and point and open-path gas detectors can be interactively positioned and oriented within any geometry. The user can highlight zero-visibility zones and interactively adjust the position or orientation of the detectors and receive real-time feedback. Detect3D is the ONLY fire and gas mapping tool on the market that can be installed on Windows workstations.
    Features:
    • Import CAD in Microstation (.dgn)* Autodesk AutoCAD® (.dxf)* STEP* IGES* OBJ and Stereolithography (.stl) formats.
    • Define multiple fire zones and assign hazard categories for each one.
    • Export the isovolumes to CAD so they can be loaded back in to your CAD software.
    • Output auto-generated reports showing coverage statistics for each fire zone in pdf and MS Excel formats.
    Fire:
    • All obstructions are accounted for automatically - no need to represent the geometry using simplified primitive shapes such as spheres and cylinders. What is in your CAD file is what will obstruct the detector.
    • The obstruction of the detector's field-of-view (FOV) is accurately calculated in full 3D by casting thousands of rays.
    • Import flame detectors from our manufacturer's database or create a custom flame detector field-of-view.
    Gas:
    • Interactively re-position or re-orient detectors and receive immediate feedback for the improved layout.
    • Add detectors one at a time or add them in a one or two dimensional array to expidite your design process.
    • Quickly highlight zero-visibility areas within each fire zone using 3D isovolumes and 2D contour plots.
    Acoustic:
    • Using technologies akin to that used for concert hall design* Insight Numerics is in development of algorithms to quickly assest the acoustic soundscape of process areas to enable engineers to optimally position acoustic gas leak detectors.
    • Insight Numerics Detect3D v2.13 + Insight Numerics Detect3D v2.13 = link
    • 101 Mb (RAR5* incl. 3% - info for restoration purpose)
    [link Point to another website Only the registered members can access] Must be loged on lavteam to see and download
  1. Detect3D software
    By zarroukbouhlel in forum Safety And Environment
    Last Post: 07-22-2015, 06:18 PM
  2. M.Sadd - Elasticity Theory, applications, and numerics
    By dongono in forum General Engineering
    Last Post: 03-06-2015, 12:03 PM
  3. Elasticity Theory, applications, and numerics - M.Sadd
    Last Post: 02-10-2015, 12:48 PM
