17.0 the ANSYS - a multi-purpose finite element package for the analysis of a wide range of engineering disciplines. It is a versatile* "heavy" finite element package for the solution in a single environment on the same finite element model problems on strength* heat* electromagnetism* fluid dynamics* multidisciplinary related analysis and optimization based on all the above mentioned types of analysis.
Hundreds of new features ANSYS v17.0 are consistent with the overall strategy of the company - development of a universal and multi-function software corresponding to the changing demands of customers. The new release was designed to meet the requirements of customers actively using the strategy the ANSYS * which is called the Simulation Driven the Product Development .
ANSYS family of products
Professional
Highly combined package for calculation of linear static problems in strength* modal analysis* the stationary and non-stationary problems thermal physics* including thermal conduction* convection and radiation exchange. ANSYS Professional is aimed at mid-level engineers.
Structural
Full Strength packet (except for the functions of calculating fluid dynamics* heat* electromagnetism) includes strength analysis function* the linear calculations of strength of the nonlinearity (strain* elasticity* plasticity* flowability* calculation of elements of the tensile and compression al.). Contact problems. Frequency domain analysis of dynamic (harmonic spectral and vibration). Dynamic analysis of transient; resistance structures; Fracture Mechanics of linear and nonlinear problems for products made of composite and fiber reinforced materials* including temperature effects. Joint analysis* acoustics.
Mechanical
This package structural analysis and heat (with the exception of the calculation functions of fluid dynamics and electromagnetics) is the most versatile module that allows to perform the majority of linear and nonlinear problems in finite element analysis. It includes all the features listed in Structural* in combination with heat calculation functions (steady and unsteady regimes* thermal conductivity* radiation* convection).
Multiphysics
The most complete package* including all possible physical disciplines (strength and heat) and electromagnetic analysis (magnetostatics* electrostatics* low-frequency harmonic analysis* high analysis) and fluid (stationary and non-stationary* compressible and incompressible* laminar and turbulent flows natural and forced convection* conjugate heat transfer* viscous and multicomponent* filtering).
Emag
Special module for calculating the electrostatic and magnetostatic* low and high frequency analysis* time-dependent problems.
LS-DYNA
Program vysokonelineynyh calculations LS-DYNA * integrated in the environment ANSYS * it combines in a single shell program traditional methods solutions with matrix inversion* specialized delivery algorithms* a plurality of equations of state and the method of integration that allows numerically simulate material molding processes* analysis of emergency collision and shock at final strains with a nonlinear material behavior and interaction of a large number of contact bodies. Using the LS-DYNA can be solved the problem of the dynamic behavior of prestressed structures and problems of structural studies unloading exposed large deformations.
ICEM CFD
A comprehensive system of generating any type of computational grids has a direct interface with CAD systems (Pro / E* Catia* of Unigraphics* I of-DEAS* SDRC's* the ICEM Surf) . Export mesh* more than 100 packets and hydro-structural analysis. Analysis and correction of geometry* pre- and post-processing* adaptive optimization of the grid - it's only the main key points to speed up the generation of high quality meshes on the basis of any geometry.
CFX
The software package combining unique features analysis hydro-processes multiphase flows* chemical kinetics* the combustion radiation heat transfer* and many others. CFX provides a new level of solving problems of computational fluid dynamics through a unique combination of technologies* ranging from the direct interfaces to most CAD systems to the ability to hold dual liquid-structural analysis* together with the ANSYS Multiphysics . A wide range of turbulence models* in combination with a linear solver with the technology of "Algebraic Coupled Multigrid" allows to achieve high accuracy in solving various classes of problems.
Workbench
A new generation of software* based modern object-oriented approach to engineering analysis* using the possibilities solvers ANSYS . This environment engineering analysis provides unique opportunities for integration with CAD systems (including bi-directional associativity). It is possible to combine the process of designing a CAD package to obtain reliable data calculation and holding of design optimization.
PrepPost
Separate pre- and post-processor with a full set of features to create* import and export of geometric models by construction* import and export of finite element meshes* on the objectives and results of processing (visualization* listing operation on the results* etc..). It is fully functional working environment and has all its functions except for the actual solution. You can use several jobs ANSYS PrepPost in combination with any settlement products.
geometric modeler
It is intended to create a geometrical model using graphics primitives operations with them and their parametric descriptions. Construction of solid model in ANSYS possible using a combination of the two variants using a set of Boolean operations finished primitives or using successive hierarchical structure starting from the reference points* then - lines* splines* and further - to a solid. The presence of these design options provides the flexibility to quickly create complex models. Supports two-way data exchange by importing models most CAD -systems including UG * Pro / E * as well as neutral geometry formats read IGES * SAT * STEP et al.
Parallel and multiprocessor systems
On parallel computing Parallel Performance for ANSYS can solve large problems as clusters.
8.97 Gb
PS Unlike Magnitude release:
1. Can ispolzvat as a local licensing (without setting the license server) and the network (from the server installation).
2. Dan additional crowbar to the integrated ANSYS SCDM 17.0 allows you to use it in the Dynamics for SpaceClaim.
3. Dan additional crowbar ANSYS 17.0 ICEPAK NETEX-G.
Must be loged on lavteam to see and download
