ARKIElétrica is a software for elaboration of projects of electrical installations. The software has a large library of symbols* which can be inserted into the project by several methods: Centralized in the environment* distributed in rows and columns according to NBR 5410* or according to the furniture and blocks of the environments. The insertion can also be done through a legend of the blocks already used in another project.
ARKILider is a program that works fully integrated within the AutoCAD program and allows to verify the requirement of limitation of energy demand (DB-HE1)* established in the Basic Document of Living and Energy of the Technical Building Code.
ARKIMediciones is a program that allows the measurement of any project from AutoCAD. This program will allow you to quickly obtain all kinds of dimensions* quantities* lengths* etc. Of the entire project.
ARKIModelo is the only program on the market that allows you to create a 3D architectural model based on 2D drawings created in AutoCAD. With this program you can take advantage of the 2D drawings that you have created in your CAD program* regardless of how you draw them. ARKIModelo will create a 3D model in a few minutes with your 2D drawings.
ARKIPlan* drawing software for architecture. This program allows you to create any architectural project from the AutoCAD program* in a quick and simple way. If you already know how to use AutoCAD* you can also use ARKIplan.
ARKITool is a set of routines and utilities to aid in the day-to-day routine of the office. These are free routines that make it easy for beginners to the most advanced AutoCAD users. ARKITool is free* click here and know the routines that will make your project to be done in much less time. Compatible with AutoCAD* GstarCAD* ZWCAD and BricsCAD.
ARKIsoft 2015 Suite + =ARKIsoft 2015 Suite link
327 Mb (RAR5* incl. 3% - info for restoration purpose)
[link Point to another website Only the registered members can access] Must be loged on lavteam to see and download
