MagiCAD is developed by the Finnish company Progman Oy* for over 25 years specializing in the development of software for the design engineering support building networks: heating* water* ventilation and electricity.
MagiCAD - an integrated approach to the design of engineering systems. MagiCAD consists of modules* each of which is fully compatible with any of the existing AutoCAD platforms.
- MagiCAD Piping intended for the design and calculation of heating* cooling* air-conditioning* water supply* sewer* sprinkler and other systems
- MagiCAD Sprinklers - a complete solution for design and calculation of sprinkler systems: you can draw and edit piping* install the equipment* determine the coverage area and work areas injectors* etc.
- MagiCAD Ventilation - a powerful tool for the design of building ventilation systems. When drawing duct is automatically selected and installed the necessary fittings. If you change the direction of the duct program will select and install the outlet. When connecting one duct to another - tee or crossbar. When changing the duct diameter is created adapter
- MagiCAD Electrical - tool for fast and efficient design of electrical* lighting and low voltage networks
- Schematics MagiCAD - solution for electrical circuits of different complexity DRAWINGS
- MagiCAD Room will create a three-dimensional model of the building* based on the true geometry and technical characteristics of the building and serves as the basis for calculations and analysis.
- Progman Oy MagiCAD for Revit MEP 2016.4 UR-1 and 2015.11 + = Progman Oy MagiCAD for Revit MEP 2016.4 UR-1 and 2015.11 link
- 783 Mb (. RAR5* incl 3% - info for restoration purpose)
PS *****ed dll was created for 2015 version* with it 2015.11 is fully licensed * also it works with 2016.4 version eigther* except one module - MagiCAD S & H
Must be loged on lavteam to see and download
