Results 1 to 5 of 5
Thread: Needed: API RP 583 Corrosion Under Insulation and Fireproofing* First Edition
    Please share API RP 583 Corrosion Under Insulation and Fireproofing* First Edition
    standard by American Petroleum Institute* 05/01/2014
    Full Description
    This recommended practice (RP) covers the design* maintenance* inspection* and mitigation practices to address external corrosion under insulation (CUI) and corrosion under fireproofing (CUF). The document discusses the external corrosion of carbon and low alloy steels under insulation and fireproofing and the external chloride stress corrosion *****ing (ECSCC) of austenitic and duplex stainless steels under insulation. The document does not cover atmospheric corrosion or corrosion at uninsulated pipe supports but does discuss corrosion at insulated pipe supports.
    The purpose of this RP is to:
    help owner/users understand the complexity of the many CUI/CUF issues;
    provide owner/users with understanding on the advantages and limitations of the various nondestructive examination methods used to identify CUI and CUF damage;
    provide owner/users with an approach to risk assessment (i.e. likelihood of failure and consequence of failure) for CUI and CUF damage; and
    provide owner/users guidance on how to design* install* and maintain insulation systems to avoid CUI and CUF damage.
    The practices described in this document apply to pressure vessels* piping* and storage tanks and spheres. The document discusses the factors impacting the damage mechanisms* the guidelines to prevent external corrosion/*****ing under insulation* the maintenance practices to avoid damage* the inspection practices to detect/assess damage* and the guidelines for risk assessment of equipment or structural steel subject to CUI and CUF damage.
    Re: Needed: API RP 583 Corrosion Under Insulation and Fireproofing* First Edition
    Got it here
  5. Re: Needed: API RP 583 Corrosion Under Insulation and Fireproofing* First Edition
    Could anybody reload API RP 583(1st edition 2014)??
  6. Re: Needed: API RP 583 Corrosion Under Insulation and Fireproofing* First Edition
    Here is the file.
  7. Re: Needed: API RP 583 Corrosion Under Insulation and Fireproofing* First Edition
    Could anybody reload the link API RP 583? Thank you very much.
  1. API 583 Corrosion Under Insulation and Fireproofing
    By mengazaa in forum General Engineering
    Last Post: 10-18-2018, 11:45 PM
  2. EFC 55 (Corrosion-Under-Insulation (CUI) Guidelines)
    By mohammed21 in forum Materials Science &Corrosion
    Last Post: 03-21-2016, 11:56 AM
  3. Corrosion under Insulation (CUI)
    By Mohamed in forum Materials Science &Corrosion
    Last Post: 02-23-2015, 07:45 AM
  4. Replies: 0
    Last Post: 10-27-2011, 02:17 PM
  5. Article: Corrosion under Insulation (CUI)
    By Mohamed in forum Home Articles
    Last Post: 08-02-2010, 07:49 PM
