full list:
IEC 60695-1-10:2016 RLV Fire hazard testing - Part 1-10: Guidance for assessing the fire hazard of electrotechnical products - General guidelines
IEC 60695-1-10:2016 Fire hazard testing - Part 1-10: Guidance for assessing the fire hazard of electrotechnical products - General guidelines
IEC 60695-1-11:2014 Fire hazard testing - Part 1-11: Guidance for assessing the fire hazard of electrotechnical products - Fire hazard assessment
IEC 60695-1-12:2015 Fire hazard testing - Part 1-12: Guidance for assessing the fire hazard of electrotechnical products - Fire safety engineering
IEC 60695-1-20:2016 Fire hazard testing - Part 1-20: Guidance for assessing the fire hazard of electrotechnical products - Ignitability - General guidance
IEC 60695-1-21:2016 Fire hazard testing - Part 1-21: Guidance for assessing the fire hazard of electrotechnical products - Ignitability - Summary and relevance of test methods
IEC 60695-1-30:2017 Fire hazard testing - Part 1-30: Guidance for assessing the fire hazard of electrotechnical products - Preselection testing process - General guidelines
IEC 60695-1-40:2013 Fire hazard testing - Part 1-40: Guidance for assessing the fire hazard of electrotechnical products - Insulating liquids
IEC 60695-2-10:2013 Fire hazard testing - Part 2-10: Glowing/hot-wire based test methods - Glow-wire apparatus and common test procedure
IEC 60695-2-11:2014 Fire hazard testing - Part 2-11: Glowing/hot-wire based test methods - Glow-wire flammability test method for end-products (GWEPT)
IEC 60695-2-11:2014 RLV Fire hazard testing – Part 2-11: Glowing/hot-wire based test methods – Glow-wire flammability test method for end-products (GWEPT)
IEC 60695-2-12:2010+AMD1:2014 CSV Fire hazard testing - Part 2-12: Glowing/hot-wire based test methods - Glow-wire flammability index (GWFI) test method for materials
IEC 60695-2-12:2010 Fire hazard testing - Part 2-12: Glowing/hot-wire based test methods - Glow-wire flammability index (GWFI) test method for materials
IEC 60695-2-12:2010/AMD1:2014 Amendment 1 - Fire hazard testing - Part 2-12: Glowing/hot-wire based test methods - Glow-wire flammability index (GWFI) test method for materials
IEC 60695-2-13:2010+AMD1:2014 CSV Fire hazard testing - Part 2-13: Glowing/hot-wire based test methods - Glow-wire ignition temperature (GWIT) test method for materials
IEC 60695-2-13:2010 Fire hazard testing - Part 2-13: Glowing/hot-wire based test methods - Glow-wire ignition temperature (GWIT) test method for materials
IEC 60695-2-13:2010/COR1:2012 Corrigendum 1 - Fire hazard testing - Part 2-13: Glowing/hot-wire based test methods - Glow-wire ignition temperature (GWIT) test method for materials
IEC 60695-2-13:2010/AMD1:2014 Amendment 1 - Fire hazard testing - Part 2-13: Glowing/hot-wire based test methods - Glow-wire ignition temperature (GWIT) test method for materials
IEC 60695-4:2012 Fire hazard testing - Part 4: Terminology concerning fire tests for electrotechnical products
IEC 60695-5-1:2002 Fire hazard testing - Part 5-1: Corrosion damage effects of fire effluent - General guidance
IEC TS 60695-5-2:2002 Fire hazard testing - Part 5-2: Corrosion damage effects of fire effluent - Summary and relevance of test methods
IEC 60695-6-1:2005+AMD1:2010 CSV Fire hazard testing - Part 6-1: Smoke obscuration - General guidance
IEC 60695-6-1:2005 Fire hazard testing - Part 6-1: Smoke obscuration - General guidance
IEC 60695-6-1:2005/AMD1:2010 Amendment 1 - Fire hazard testing - Part 6-1: Smoke obscuration - General guidance
IEC 60695-6-2:2011 Fire hazard testing - Part 6-2: Smoke obscuration - Summary and relevance of test methods
IEC 60695-7-1:2010 Fire hazard testing - Part 7-1: Toxicity of fire effluent - General guidance
IEC 60695-7-2:2011 Fire hazard testing - Part 7-2: Toxicity of fire effluent - Summary and relevance of test methods
IEC 60695-7-3:2011 Fire hazard testing - Part 7-3: Toxicity of fire effluent - Use and interpretation of test results
IEC 60695-8-1:2016 Fire hazard testing - Part 8-1: Heat release - General guidance
IEC 60695-8-2:2016 Fire hazard testing - Part 8-2: Heat release - Summary and relevance of test methods
IEC 60695-9-1:2013 Fire hazard testing - Part 9-1: Surface spread of flame - General guidance
IEC 60695-9-2:2014 Fire hazard testing - Part 9-2: Surface spread of flame - Summary and relevance of test methods
IEC 60695-10-2:2014 Fire hazard testing - Part 10-2: Abnormal heat - Ball pressure test method
IEC 60695-10-3:2016 Fire hazard testing - Part 10-3: Abnormal heat - Mould stress relief distortion test
IEC 60695-11-2:2013 Fire hazard testing - Part 11-2: Test flames - 1 kW pre-mixed flame - Apparatus* confirmatory test arrangement and guidance
IEC 60695-11-3:2012 Fire hazard testing - Part 11-3: Test flames - 500 W flames - Apparatus and confirmational test methods
IEC 60695-11-4:2011 Fire hazard testing - Part 11-4: Test flames - 50 W flame - Apparatus and confirmational test method
IEC 60695-11-5:2016 Fire hazard testing - Part 11-5: Test flames - Needle-flame test method - Apparatus* confirmatory test arrangement and guidance
IEC 60695-11-5:2016 RLV Fire hazard testing - Part 11-5: Test flames - Needle-flame test method - Apparatus* confirmatory test arrangement and guidance
IEC 60695-11-10:2013 Fire hazard testing - Part 11-10: Test flames - 50 W horizontal and vertical flame test methods
IEC 60695-11-10:2013/COR1:2014 Corrigendum 1 - Fire hazard testing - Part 11-10: Test flames - 50 W horizontal and vertical flame test methods
IEC TS 60695-11-11:2016 Fire hazard testing - Part 11-11: Test flames - Determination of the characteristic heat flux for ignition from a non-contacting flame source
IEC 60695-11-20:2015 Fire hazard testing - Part 11-20: Test flames - 500 W flame test method
IEC 60695-11-20:2015/COR1:2016 Corrigendum 1 - Fire hazard testing - Part 11-20: Test flames - 500 W flame test method
IEC TR 60695-11-30:2001 Fire hazard testing - Part 11-30: Test flames - History and development from 1979 to 1999
IEC TS 60695-11-40:2002 Fire hazard testing - Part 11-40: Test flames - Confirmatory tests - Guidance
ISO 13943:2008 Fire safety - Vocabulary
the missing list:
well* the missing are seperately some AMDs* but they are included in CSV version...also so called "RLV" version are missing* but what's actually missing here is:
