Results 1 to 1 of 1
Thread: how to calculate drainage radius of a vertical well? please need help
  1. how to calculate drainage radius of a vertical well? please need help
    we are going to drill a new vertical well wich is spaced about 600 m about the existing producer (it's average oil rate is about 9m3/hr and cum oil about 260000 m3)* we have only DST data for this producer (no pressure data after 3years of production)* the kh was about 160mdm (it's well test response matchs Infinite acting radial flow).
    I desagree with this spacing*I found it small* for me if we will drill this well we will interfere with the existing well* as result we will bring quickly the reservoir pressure below Pb pressure.
    They are saying we are allowed to drill at this distance because it's a tight reservoir (but kh=160mdm considered among the best wells* the tighter one has a kh about 20mdm)
    How I can convince my manager?
    I searched on the internet how to calculate the drainage area of a vertical well* because I was told that the radius of investigation of the DST is not the same as that of the production* I got confused.
    Radius of investigation represents how far into the reservoir the transient effects have traveled.
    I want to do hand calculation in order to check? I need your precious help.
  1. Article: Drainage Radius Estimation
    By elevenfourth in forum Home Articles
    Last Post: 03-24-2013, 10:52 PM
  2. Article: Drainage Radius Estimation
    Last Post: 03-24-2013, 10:51 PM
  3. Drainage Radius Estimation
    By elevenfourth in forum Reservoir
    Last Post: 03-22-2013, 09:00 AM
  4. Article: Drainage Radius Estimation
    Last Post: 03-16-2013, 02:43 AM
  5. Drainage radius
    By TBone in forum Reservoir
    Last Post: 10-20-2010, 12:28 PM
