Thread: Firetube Questions
  1. Firetube Questions
    I’m projecting a heat treater as shown below.
    In my study I’m using a 30°API oil with an inlet flow rate of 3800bbl/d* 1170bbl/d water flow rate and 0.8MMscfd gas flow rate* the operating temperature is 120°F and field temperature 68°F. The fuel used in the firetube is natural gas and the Inferior calorific value is 47MJ/kg. The capacity for the firetube in our project needs to be 1*75MMBTU/hr and we would like a firetube with 24’’ diameter.
    Data:
    Vessel Size 8’x25’: Diameter 8 ft x Length 25 ft
    Inferior calorific value: 1*75MMBTU/hr
    Firetube diamater: 24 inches
    Oil: 30°API
    Field ( ambient) temperature(inlet): 68°F
    Vessel Operating temperature: 120°F
    Oil flow rate: 3*800bbl/d (barrels per day)
    Water flow rate: 1170bbl/d
    Gas flow rate: 0.8MMscfd
    Inferioc caloric value: 47MJ/kg
    i)Which would be the firetube length ? How do I calculate this?
    ii)About the convection section of the firetube* do you include a firetube turbulator? If yes* how do you evaluate the influence of this in the firetube length?
    iii)Which would be the firetube flux (Q/A)?
    iv)If I use a forced draft blower the firetube flux(Q/A) would increase ? If yes* what is the ideal air flow rate forced by the blower?
    v)What would be the operation pressure inside the firetube?
    Re: Firetube Questions
    You may use the book as guideline to do the calc- Oilfield Surface Facilities Handbook.
  1. Questions
    By indianadarren in forum Oil And Gas Production
    Last Post: 02-01-2016, 11:06 AM
  2. Questions
    Last Post: 08-15-2013, 12:29 AM
  3. questions about IEM
    By hawk1lo in forum Self Improvement
    Last Post: 06-26-2013, 03:52 AM
  4. Some questions
    Last Post: 09-17-2012, 12:58 PM
