Thread: Welding pad into existing pipe trunion
    Dear Experts*
    Would you please advice is there any code restrict to conduct additional pad on pipe trunion without further hydrotest.
    Thank you*
    Yogie. M
  3. Re: Welding pad into existing pipe trunion
    Dear Yogie. M*
    It is not clear whether you want to weld the pad on the pipe trunnion (non-pressure part) or to reinforcing pad already present on shell or to the pressure part shell directly.
    It is also important to know whether your equipment is subjected to PWHT or not* Code stamped (since permission will be required from the AI) etc.
    I suggest you refer to the NBIC Part 3 code and check whether your work falls into repair category* alteration category or routine work category.
    Hope it helps.
    Regards*
    If you are welding to the pressure membrane you are performing hot work onto the pressure membrane therefore you should ideally perform a pressure test to prove the integrity!!!
  1. Pipe Welding Procedures
    By Abdel fatah in forum Materials Science &Corrosion
    Last Post: 05-14-2016, 10:47 AM
  2. Pipe Welding Procedures
    By SHEMYY in forum Mechanical Engineering
    Last Post: 05-12-2014, 10:52 AM
  3. Pipe welding procedures
    By vfq3481 in forum Mechanical Engineering
    Last Post: 10-26-2012, 02:59 PM
  4. Pipe Welding
    By Mr Welder in forum Mechanical Engineering
    Last Post: 07-21-2011, 09:09 AM
  5. A-333 Gr.7 pipe / A-420 WPL3 Welding
    By er_scec in forum Materials Science &Corrosion
    Last Post: 06-18-2011, 07:16 AM
