ISO/TC 27
ISO 11760:2005 Classification of coals
Coal preparation: Terminology and performance
ISO 561:1989 Coal preparation plant -- Graphical symbols
ISO 923:2000 Coal cleaning equipment -- Performance evaluation
ISO 924:1989 Coal preparation plant -- Principles and conventions for flowsheets
ISO 1213-1:1993 Solid mineral fuels -- Vocabulary -- Part 1: Terms relating to coal preparation
ISO 1213-2:2016 Solid mineral fuels -- Vocabulary -- Part 2: Terms relating to sampling* testing and analysis
ISO 1953:2015 Hard coal -- Size analysis by sieving
ISO 7936:1992 Hard coal -- Determination and presentation of float and sink characteristics -- General directions for apparatus and procedures
ISO 8833:1989 Magnetite for use in coal preparation -- Test methods
ISO 8858-1:1990 Hard coal -- Froth flotation testing -- Part 1: Laboratory procedure
ISO 8858-2:2004 Hard coal -- Froth flotation testing -- Part 2: Sequential evaluation
ISO 8858-3:2004 Hard coal -- Froth flotation testing -- Part 3: Release evaluation
ISO 10086-1:2000 Coal -- Methods for evaluating flocculants for use in coal preparation -- Part 1: Basic parameters
ISO 10086-2:2004 Coal -- Methods for evaluating flocculants for use in coal preparation -- Part 2: Flocculants as filter aids in rotary vacuum filtration systems
ISO 10752:1994 Coal sizing equipment -- Performance evaluation
ISO 10753:1994 Coal preparation plant -- Assessment of the liability to breakdown in water of materials associated with coal seams
ISO 15117-1:2004 Coal flow properties -- Part 1: Bin flow
ISO 15239:2005 Solid mineral fuels -- Evaluation of the measurement performance of on-line analysers
ISO 20905:2004 Coal preparation -- Determination of dust/moisture relationship for coal
ISO 23499:2013 Coal -- Determination of bulk density for the use in charging of coke ovens
Coke
ISO 556:1980 Coke (greater than 20 mm in size) -- Determination of mechanical strength
ISO 567:1995 Coke -- Determination of bulk density in a small container
ISO 616:1995 Coke -- Determination of shatter indices
ISO 728:1995 Coke (nominal top size greater than 20 mm) -- Size analysis by sieving
ISO 1013:1995 Coke -- Determination of bulk density in a large container
ISO 1014:1985 Coke -- Determination of true relative density* apparent relative density and porosity
ISO 1014:1985/Cor 1:1994 Coke -- Determination of true relative density* apparent relative density and porosity
ISO 2325:1986 Coke -- Size analysis (Nominal top size 20 mm or less)
ISO 18894:2006 Coke -- Determination of coke reactivity index (CRI) and coke strength after reaction (CSR)
Sampling
ISO 5069-1:1983 Brown coals and lignites -- Principles of sampling -- Part 1: Sampling for determination of moisture content and for general analysis
ISO 5069-2:1983 Brown coals and lignites -- Principles of sampling -- Part 2: Sample preparation for determination of moisture content and for general analysis
ISO 9931:1991 Coal -- Sampling of pulverized coal conveyed by gases in direct fired coal system
ISO 13909-1:2016 Hard coal and coke -- Mechanical sampling -- Part 1: General introduction
ISO 13909-2:2016 Hard coal and coke -- Mechanical sampling -- Part 2: Coal -- Sampling from moving streams
ISO 13909-3:2016 Hard coal and coke -- Mechanical sampling -- Part 3: Coal -- Sampling from stationary lots
ISO 13909-4:2016 Hard coal and coke -- Mechanical sampling -- Part 4: Coal -- Preparation of test samples
ISO 13909-5:2016 Hard coal and coke -- Mechanical sampling -- Part 5: Coke -- Sampling from moving streams
ISO 13909-6:2016 Hard coal and coke -- Mechanical sampling -- Part 6: Coke -- Preparation of test samples
ISO 13909-7:2016 Hard coal and coke -- Mechanical sampling -- Part 7: Methods for determining the precision of sampling* sample preparation and testing
ISO 13909-8:2016 Hard coal and coke -- Mechanical sampling -- Part 8: Methods of testing for bias
ISO 14180:1998 Solid mineral fuels -- Guidance on the sampling of coal seams
ISO 18283:2006 Hard coal and coke -- Manual sampling
ISO 18283:2006/Cor 1:2009 Hard coal and coke -- Manual sampling
ISO 20904:2006 Hard coal -- Sampling of slurries
ISO 21398:2007 Hard coal and coke -- Guidance to the inspection of mechanical sampling systems
Methods of analysis
ISO 157:1996 Coal -- Determination of forms of sulfur
ISO 157:1996/Cor 1:1999 Coal -- Determination of forms of sulfur
ISO 334:2013 Solid mineral fuels -- Determination of total sulfur -- Eschka method
ISO 349:1975 Hard coal -- Audibert-Arnu dilatometer test
ISO 501:2012 Hard coal -- Determination of the crucible swelling number
ISO 502:2015 Coal -- Determination of caking power -- Gray-King coke test
ISO 540:2008 Hard coal and coke -- Determination of ash fusibility
ISO 562:2010 Hard coal and coke -- Determination of volatile matter
ISO 579:2013 Coke -- Determination of total moisture
ISO 587:1997 Solid mineral fuels -- Determination of chlorine using Eschka mixture
ISO 589:2008 Hard coal -- Determination of total moisture
ISO 602:2015 Coal -- Determination of mineral matter
ISO 609:1996 Solid mineral fuels -- Determination of carbon and hydrogen -- High temperature combustion method
ISO 609:1996/Cor 1:1996 Solid mineral fuels -- Determination of carbon and hydrogen -- High temperature combustion method
ISO 622:2016 Solid mineral fuels -- Determination of phosphorus content -- Reduced molybdophosphate photometric method
ISO 625:1996 Solid mineral fuels -- Determination of carbon and hydrogen -- Liebig method
ISO 625:1996/Cor 1:1996 Solid mineral fuels -- Determination of carbon and hydrogen -- Liebig method
ISO 647:1974 Brown coals and lignites -- Determination of the yields of tar* water* gas and coke residue by low temperature distillation
ISO 687:2010 Solid mineral fuels -- Coke -- Determination of moisture in the general analysis test sample
ISO 925:1997 Solid mineral fuels -- Determination of carbonate carbon content -- Gravimetric method
ISO 975:2013 Brown coals and lignites -- Determination of yield of benzene-soluble extract -- Semi-automatic method
ISO 1017:2006 Brown coals and lignites -- Determination of acetone-soluble material ("resinous substance") in the benzene-soluble extract
ISO 1018:1975 Hard coal -- Determination of moisture-holding capacity
ISO 10329:2009 Coal -- Determination of plastic properties -- Constant-torque Gieseler plastometer method
ISO 1170:2013 Coal and coke -- Calculation of analyses to different bases
ISO 1171:2010 Solid mineral fuels -- Determination of ash
ISO 1928:2009 Solid mineral fuels -- Determination of gross calorific value by the bomb calorimetric method and calculation of net calorific value
ISO 1952:2008 Solid mineral fuels -- Determination of extractable metals in dilute hydrochloric acid
ISO 2950:1974 Brown coals and lignites -- Classification by types on the basis of total moisture content and tar yield
ISO 5068-1:2007 Brown coals and lignites -- Determination of moisture content -- Part 1: Indirect gravimetric method for total moisture
ISO 5068-2:2007 Brown coals and lignites -- Determination of moisture content -- Part 2: Indirect gravimetric method for moisture in the analysis sample
ISO 5071-1:2013 Brown coals and lignites -- Determination of the volatile matter in the analysis sample -- Part 1: Two-furnace method
ISO 5072:2013 Brown coals and lignites -- Determination of true relative density and apparent relative density
ISO 5073:2013 Brown coals and lignites -- Determination of humic acids
ISO 5074:2015 Hard coal -- Determination of Hardgrove grindability index
ISO 7404-1:2016 Methods for the petrographic analysis of coals -- Part 1: Vocabulary
ISO 7404-2:2009 Methods for the petrographic analysis of coals -- Part 2: Methods of preparing coal samples
ISO 7404-3:2009 Methods for the petrographic analysis of coals -- Part 3: Method of determining maceral group composition
ISO 7404-4:1988 Methods for the petrographic analysis of bituminous coal and anthracite -- Part 4: Method of determining microlithotype* carbominerite and minerite composition
ISO 7404-5:2009 Methods for the petrographic analysis of coals -- Part 5: Method of determining microscopically the reflectance of vitrinite
ISO 8264:1989 Hard coal -- Determination of the swelling properties using a dilatometer
ISO 11722:2013 Solid mineral fuels -- Hard coal -- Determination of moisture in the general analysis test sample by drying in nitrogen
ISO 11723:2016 Solid mineral fuels -- Determination of arsenic and selenium -- Eschka's mixture and hydride generation method
ISO 11724:2016 Solid mineral fuels -- Determination of total fluorine in coal* coke and fly ash
ISO 11726:2004 Solid mineral fuels -- Guidelines for the validation of alternative methods of analysis
ISO 12900:2015 Hard coal -- Determination of abrasiveness
ISO/TS 13605:2012 Solid mineral fuels -- Major and minor elements in hard coal ash and coke ash -- Wavelength dispersive X-ray fluorescence spectrometric method
ISO 15237:2016 Solid mineral fuels -- Determination of total mercury content of coal
ISO 15238:2016 Solid mineral fuels -- Determination of total cadmium content of coal
ISO 15585:2006 Hard coal -- Determination of caking index
ISO 17246:2010 Coal -- Proximate analysis
ISO 17247:2013 Coal -- Ultimate analysis
ISO/TS 18806:2014 Solid mineral fuels -- Determination of Chlorine content
ISO 19579:2006 Solid mineral fuels -- Determination of sulfur by IR spectrometry
ISO 23380:2013 Selection of methods for the determination of trace elements in coal
ISO 23873:2010 Hard coal -- Method for the measurement of the swelling of hard coal using a dilatometer
ISO 29541:2010 Solid mineral fuels -- Determination of total carbon* hydrogen and nitrogen content -- Instrumental method
the missing are:
the link:
