ISO/TC 186
ISO/R 916:1968 Testing of refrigerating systems
Safety and environmental requirements for refrigerating systems
ISO 5149-1:2014 Refrigerating systems and heat pumps -- Safety and environmental requirements -- Part 1: Definitions* classification and selection criteria
ISO 5149-1:2014/Amd 1:2015 Correction of QLAV* QLMV
ISO 5149-2:2014 Refrigerating systems and heat pumps -- Safety and environmental requirements -- Part 2: Design* construction* testing* marking and documentation
ISO 5149-3:2014 Refrigerating systems and heat pumps -- Safety and environmental requirements -- Part 3: Installation site
ISO 5149-4:2014 Refrigerating systems and heat pumps -- Safety and environmental requirements -- Part 4: Operation* maintenance* repair and recovery
ISO 13971:2012 Refrigeration systems and heat pumps -- Flexible pipe elements* vibration isolators* expansion joints and non-metallic tubes -- Requirements and classification
ISO 14903:2012 Refrigerating systems and heat pumps -- Qualification of tightness of components and joints
Testing and rating of air-conditioners and heat pumps
ISO 5151:2010 Non-ducted air conditioners and heat pumps -- Testing and rating for performance
ISO 13253:2011 Ducted air-conditioners and air-to-air heat pumps -- Testing and rating for performance
ISO 13256-1:1998 Water-source heat pumps -- Testing and rating for performance -- Part 1: Water-to-air and brine-to-air heat pumps
ISO 13256-2:1998 Water-source heat pumps -- Testing and rating for performance -- Part 2: Water-to-water and brine-to-water heat pumps
ISO 13261-1:1998 Sound power rating of air-conditioning and air-source heat pump equipment -- Part 1: Non-ducted outdoor equipment
ISO 13261-2:1998 Sound power rating of air-conditioning and air-source heat pump equipment -- Part 2: Non-ducted indoor equipment
ISO 15042:2011 Multiple split-system air-conditioners and air-to-air heat pumps -- Testing and rating for performance
ISO 16345:2014 Water-cooling towers -- Testing and rating of thermal performance
ISO 16358-1:2013 Air-cooled air conditioners and air-to-air heat pumps -- Testing and calculating methods for seasonal performance factors -- Part 1: Cooling seasonal performance factor
ISO 16358-1:2013/Cor 1:2013 Air-cooled air conditioners and air-to-air heat pumps -- Testing and calculating methods for seasonal performance factors -- Part 1: Cooling seasonal performance factor
ISO 16358-2:2013 Air-cooled air conditioners and air-to-air heat pumps -- Testing and calculating methods for seasonal performance factors -- Part 2: Heating seasonal performance factor
ISO 16358-2:2013/Cor 1:2013 Air-cooled air conditioners and air-to-air heat pumps -- Testing and calculating methods for seasonal performance factors -- Part 2: Heating seasonal performance factor
ISO 16358-3:2013 Air-cooled air conditioners and air-to-air heat pumps -- Testing and calculating methods for seasonal performance factors -- Part 3: Annual performance factor
ISO/TS 16491:2012 Guidelines for the evaluation of uncertainty of measurement in air conditioner and heat pump cooling and heating capacity tests
ISO 16494:2014 Heat recovery ventilators and energy recovery ventilators -- Method of test for performance
Testing and rating of commercial refrigerated display cabinets
ISO 23953-1:2015 Refrigerated display cabinets -- Part 1: Vocabulary
ISO 23953-2:2015 Refrigerated display cabinets -- Part 2: Classification* requirements and test conditions
Refrigerants and refrigeration lubricants
ISO 817:2014 Refrigerants -- Designation and safety classification
ISO 11650:1999 Performance of refrigerant recovery and/or recycling equipment
ISO 17584:2005 Refrigerant properties
the missing are:
link:
