This is related to possible arrangement of exchangers for series configuration, their pros and cons.
I am designing a Feed bottom exchanger with cold side approach of 40°F.
Temperature cross exists and hence i opted 2 shells in series .
Initially i designed AES (E shell) and it took a considerable amount of time, since i faced a reverse heat flow in one of the shells. Finally i managed to get rid of it by increasing the tube passes and tuning relevant parameters.
But later , i tried AFS in series and found that there was no problem of reverse heat flow. Furthermore i was able to reduce required heat transfer by about 25% compared to AES in series.
My question :
Most reference show AES in series, and i havent come across AFS in series.
Can somebody advise me if AFS in series is acceptable.
Does this configuration have any kind of drawback, or problems.
