Energy saving opportunities for the boiler (Firing side)
- Preheat combustion air with waste heat (22 C reduction in flue gas temperature increases boiler efficiency by 1%).
- Use variable speed drives on large boiler combustion air fans with variable flows.
- Improve oxygen trim control (e.g. — limit excess air to less than 10% on clean fuels). 5% reduction in excess air increases boiler efficiency by 1% or: 1% reduction of residual oxygen in stack gas increases boiler efficiency by 1%.)
- Inspect for soot* flyash* and slag on the fire side (A 3 mm thick soot deposition on the heat transfer surface can cause an increase in fuel consumption to the tune of 2.5%.)
to see the description video (Arabic and English versions) and download the slide please check the below link
or this link
For more energy saving tips* please visit[link Point to another website Only the registered members can access]
