Thread: Anti-channel drain baffle
  1. Anti-channel drain baffle
    Does anyone know what this additional fitting is used for in a tank?
    It is mentioned as an option when specifying an API 12F tank.
    Sounds like a 'box' on the end of the low point drain* inside the tank.
    Is it about sediment or keeping oil out of this drain. Oil that is floating on top of the water. Thus only letting the last bit of water out of the tank.
    / DLK
    Re: Anti-channel drain baffle
    You are on target* it keeps some sediment back as well as oil and allows water through due to the 1" minimum gap at the bottom. It is a minimum 64" periphery * (16" x 16" box)
    I acts a little like an anti-vortex device.
  1. Don't Let Baffling Baffle You
    By dongono in forum General Engineering
    Last Post: 02-09-2015, 09:44 AM
  2. Baffle cut orientation for Heat exchanger
    By liu1026 in forum Mechanical Engineering
    Last Post: 05-22-2013, 05:02 AM
  3. Rod baffle heat exchanger
    By engr.abrar in forum Petrochemical
    Last Post: 10-25-2009, 08:59 AM
