Results 1 to 12 of 12
Thread: Cymgrd 7.0
    Cymgrd 7.0
    The CYMGRD software is a substation grounding grid design and analysis program specially developed to help engineers optimize the design of new grids and reinforce existing grids* of any shape* by virtue of easy to use* built-in danger point evaluation facilities. User-friendly data entry* efficient analysis algorithms and powerful graphical facilities make the CYMGRD software an efficient tool which helps engineers arrive at technically sound and economical designs.
    New Release - CYMGRD 7.0 combines industry-led features and engineering know-how to deliver a solution for the safe and optimal design of new grids and the reinforcement of existing grids.
    CYMGRD 7.0 offers a wide range of enhanced capabilities and new functionalities:
    International safety standards are now supported
    Data entry based on the Schlumburger-Palmer Measurement method
    Multiple Soil Measurement Axes
    Complete global report of all analysis
    User-friendly data entry* efficient analysis algorithms and powerful graphical facilities make the CYMGRD software an efficient tool that helps the engineer arrive at technically sound and economical designs.
    Program Features
    The use of the CYMGRD software allows for the rapid analysis of various design alternatives to choose an economical solution for any particular installation.
    The program conforms to IEEE 80™ 2000* IEEE 81™ 1983 and IEEE 837™ 2002.
    Analytical Capabilities
    Finite element analysis of the ground grid conductors and rods
    Computation of the station ground resistance (Rg) and the Ground Potential Rise (GPR)
    Touch and surface potential analysis* inside and outside the grid perimeter* with color display in 2D or 3D representation
    Step voltage analysis
    Uniform or two-layer soil model from field measurements or user-defined values
    Computation of reduction factor (Cs)
    Library of the most common types of surface layer materials
    Library of typical station soil resistivity values
    Safety assessment calculations for maximum permissible touch and step voltages as per IEEE 80™ 2000
    Current Split Factor (SF) estimated from substation configuration data as per IEEE 80™ 2000
    Computation of the Decrement Factor (DF) from bus (X/R) ratio and shock duration data as per IEEE 80™ 2000
    DC component of asymmetrical fault current taken into account in the computations
    Electrode analysis for the optimal sizing of conductors and rods based on the most common type of electrode material as per IEEE Std. 80-2000 and Std. 837-2002
    Supports symmetrical or asymmetrical grids of any shape
    Arbitrarily located ground rods
    Ability to model return electrodes and distinct electrodes
    Ability to model concrete encased rods
    Computation of maximum single phase to ground fault current for a specified grid
    The CYMGRD/AutoCAD® Interface module
    The CYMGRD / AutoCAD® Interface module allows the user to alternate between the AutoCAD® and the CYMGRD environments.
    This utility is not a substitute for AutoCAD®. In fact* AutoCAD® remains a firm software requirement for CADGRD* because it is AutoCAD® that will produce the necessary *.DXF or *.DWG file(s) that contain the pictorial description of the substation grid layout realized with the CYMGRD software.
    Simulation Results Management
    The charts functionality allows:
    Graphical comparison of deduced soil model with field measurements* for model acceptance
    Color-coding of the surface potential gradients based on user-defined thresholds for touch or surface potentials. Any area of the grid can be selected with the mouse for detailed calculations and danger point evaluation
    Equipotential contours for surface potentials in either 2-D or 3-D plots* with facilities to examine the graphs from any desired viewing angle
    Graphics of touch and step voltage variation along any straight line* with comparison to the safe values computed by the safety assessment module
    Graphic indications on the 2-D grid layout of the area being analyzed for touch and step voltages* for easy identification of hazardous locations
    Looks* sounds* smells expensive too.
    Btw what is the latest cymtcc?
    Sent from my SM-J710GN using Tapatalk
    Re: Cymgrd 7.0
    Quote Originally Posted by mukhriz View Post
    etap is a package that combine a lot of aplications in different modules in one software. but cyme not
    cyme has a software for each aplication:
    • CYME - Applications for Transmission and Industrial power systems analysis
    • allowing the user to engage in advanced system planning studies to optimize system performance* examine cost-efficient operational planning alternatives - (CYM PSAF)
    • CYMDIST - CYME Applications for Distribution power systems analysis
    • Cable Ampacity Calculations - (CYMCAP)
    • Protective Device Coordination - (CYMTCC)
    • Grounding Grid Design and Analysis - (CYMGRD)
    • Electromagnetic Transients Simulation and Analysis - (EMTP)
    I mean what is the latest Cymtcc version since we have Cyme8 and 7.2 out there.
    Star5...do you have latest cymtcc...i just get to know i cant do coordination without cymtcc
    anyone has the latest cymtcc and other cym sub module...
    Sent from my ASUS_T00J using Tapatalk
    I only use old version. Still proves okay. And database can be updated. But the difficult part is always on aligning curves to fault response. Digsilent* etap and aspen works best..even excel is good.
    Sent from my GT-I9082 using Tapatalk
  11. Re: Cymgrd 7.0
    Hola* necesito el CYMGRD* por favor compartirlo. Gracias
  12. Re: Cymgrd 7.0
    por favor compartan el CYMGRD. Gracias
  13. Re: Cymgrd 7.0
    I didn't know that EMTP and CYMGRD has been developed by the same company, i just used them, thanks for the information.
  14. Re: Cymgrd 7.0
    Yo tengo la v6.3
  16. Re: Cymgrd 7.0
    Quote Originally Posted by williamb285 View Post
    Bro, yo publique la version 6.3 si te sirve
    [link Point to another website Only the registered members can access] Saludos,
    Read more:
  1. Cymgrd
    By sperb in forum Electrical & Power Engineering
    Last Post: 10-23-2013, 10:16 PM
