Results 1 to 7 of 7
Thread: What (standard? definition?)would you use to calculate these cables?
  1. What (standard? definition?)would you use to calculate these cables?
    Re: What (standard? definition?)would you use to calculate these cables?
    Use Cymcap Software
    or even etap software
    Quote Originally Posted by fgf View Post
    Good question* I would make guess* cable inside conduit in 'air'.
    If cable surround by dirt/clay when buried* harder for temperature to dissipate. In tunnel* air still flow and can cool cable temperature.
    For this calculation I would apply ambient temperature derating factor as underground tunnel temperature higher I guess than normal 'air' and cable proximity derating factor.
    Cable size guide standards to use-> BS7671 or IEC
  6. Re: What (standard? definition?)would you use to calculate these cables?
    Thank you for understanding and answering this question
    Welcome.
    those are cables in trenches. look for a standard for this calculation with this term
    IEEE Recommended Practice for Cable Installation in Generating Stations and Industrial Facilities
    IEEE Std 1185-2010 (Revision of IEEE Std 1185-1994)
    or ie:
  10. Re: What (standard? definition?)would you use to calculate these cables?
    Thanks!
    As for the simulation*
    Those of us with CYMCAP 4.2 don't have the "cables in trenches" option
    we came up with a solution (sort of )* use raceway and set the RHO of the raceway to 0
  1. Risk definition for sva
    By kohkin in forum Safety And Environment
    Last Post: 08-17-2013, 09:23 AM
  2. Export Pipeline - definition
    By Nurikos in forum Pipeline And Fluid Flow
    Last Post: 02-12-2013, 06:51 AM
  3. BS/IEC standard for instrumentation cables
    By amshah in forum Instrumentation & Control
    Last Post: 07-19-2011, 07:08 AM
  4. Draka Cables and Tables
    By krep22 in forum Electrical & Power Engineering
    Last Post: 06-11-2011, 12:47 PM
